Old 11-12-2006, 01:43 AM   #775
BMGYaris
Drives: Yaris 3dr Hatchback
Originally Posted by regulus
so best thing i guess is start counting from the second bar until the 7th vanishes. Ill try that
I never meant to ignore the first bar in your calculations. I just meant that the gas fuel guage is not precise, it is just rough estimates as to how much gas is still left in your tank. Thus no bar or number of bars represents exactly what it does mathematically (mathematically each bar equals 1.387 gallons, but in reality it will not drop at that precise moment). Suppose that on your first bar it was off .21 gallons off. that would be something about 15% more fuel consumed than what you mathematically yield should have been used on your first bar. But the more bars that are gone then the less the margin of error impacts your calculations.
So what this means is that on one bar the margin of error is going to represent some range of fuel consumption, lets say anything from 5-25% more than what you would expect that first bar to actually represent. However, as you use more gas, the actual margin of error (say .21 gallons) should remain pretty consistent (within a range). That means that if .21 gallons creates a 16% inaccuracy when guestimating from your first bar, you will find that the % inaccuracy decreases as your fuel consumption increases. Thus as the total gallons consumed increases the error will represent a smaller portion of your gas consumption. Meaning the more gas consumed the more accurate your bar guage will be, though no one particular bar will be any more accurate than any other. You should always calculate with all available information
Note: im only talking about rough guesstimating before fill ups. Obviously the only way to get true readings is to fill up many times at the same pump. I just didnt want him too be too shocked when his 35 mpg city turned in to 29 or 30...hopefully 32.
BMGYaris is offline   Reply With Quote
Old 11-12-2006, 09:00 AM   #776
regulus
Drives: yaris sedan
Thanks both for the info :D
Ill keep you posted
regulus is offline   Reply With Quote
Old 11-12-2006, 05:38 PM   #777
swng
swng's Avatar
Drives: 06 3-dr auto RS
You are welcome and good luck!
BMGYaris' advice makes lot of sense to me. I admire the meticulous calculations.
In my layman's language, all bars do not necessarily represent the same amout of fuel and hence mileage. Depending on how full the tank is filled up, the first bar usually represents anything from more to a lot more fuel than the others. Trying to estimate a car's fuel economy with the data collected from just one bar can lead to a rather unreliable result. The bigger is the database, the better.
Long term averaging and consistency in filling up location(s) and method (I would say) can help minimize the effects of many possible errors.
Good research friends!
swng is offline   Reply With Quote
Old 11-14-2006, 09:41 PM   #778
keesue
Chillin' out by the Bay
keesue's Avatar
Very first tankful = 35.6 miles/gallon
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 11-15-2006, 05:25 PM   #779
swng
swng's Avatar
The result is quite good keesue, considering that it's your first tank and that winter has arrived (weather should not be severe in San Francisco right now though). I presume you are reporting in miles per US gallon. That will be more than 42.5 miles per Imperial gallon.
Please keep on posting your results from time to time and describe your driving style and the traffic and load conditions leading to your results every now and then if you don't mind.
Thanks!
Old 11-15-2006, 09:43 PM   #780
keesue
keesue's Avatar
I sure will. These miles are 85% commuting. I drive at an average of 65 miles/hour. I expect, as the engine breaks in, to get another mile/gallon. I'll keep you posted.
Old 11-15-2006, 10:58 PM   #781
swng
swng's Avatar
Thank you in anticipation keesue!
Old 11-16-2006, 12:22 AM   #782
spkrman
Drives: 1
average of 30 mpg over almost 4 gallons, lots of idling (approx 30-40 mins worth)... lots of agressive driving/acceleration, and mostly city miles... pretty awesome given the circumstances!
BP regular gas, btw.
Old 11-16-2006, 09:18 PM   #783
SimplyYaris
SimplyYaris's Avatar
Drives: Red Yaris HB
First tank of gas - 80/20 city/highway 36 mpg. Yes!
SimplyYaris is offline   Reply With Quote
Old 11-16-2006, 11:14 PM   #784
swng
swng's Avatar
Latest Tank (not good because of up to 35% of hilly/stop and go city driving):
Fuel Cost
$37.66 (Canadian)
Distance Travelled
533.9 km
331.77 miles
Fuel Amount
39.07 litres
10.32 US gallons
8.59 Imperial gallons
Cost of Fuel
$0.96 per litre
$3.65 per US gallon
$4.38 per Imperial gallon
Fuel Economy
7.32
litres per 100 km
32.14
miles per US gallon
38.61
Mileage Costs
7.0538
¢ents per km
11.35
¢ents per mile
Old 11-17-2006, 05:54 AM   #785
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
my last tank of gas i got 43.1MPG But this tank isn't going to be as good bad weather having to run my deforst a lot wish that had't linked it to the a/c
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 11-17-2006, 08:48 AM   #786
palsan
Drives: yaris 3 dr hatch
Originally Posted by gonzo452001
my last tank of gas i got 43.1MPG...
I'm assuming from your profile that you are in French Lick, Indiana, so I'm guessing your numbers are in US gallons. So, how is 43.1MPG (5.46L/100Km) possible? (If it's imperial gallons I apologize in advance)
Have you stripped the interior of the car, removed the seats, removed the spare tire, stripped the paint, ... ?
I mean, Toyota rates the car as follows:
Manual (city/hwy) 6.9/5.5
Automatic (city/hway) 7.0/5.6
Real world results are normally worse than the manufacturer spec sheet, yet you are reporting BETTER results than the 100% hwy numbers. How is that possible?
palsan is offline   Reply With Quote
Old 11-17-2006, 01:16 PM   #787
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
my BEST tank was 44.2mpg (US). this was a full tank which included a drive to Vermont with my girlfriend, my bike/wheels on the back & all my gear in the car.
I drove 58-60mph the whole way & coasted in neutral down every hill.
This summer i was consistently getting 40-42mpg without too much effort other than keep my highway speeds to 60mph & coasting when i could.
Lately, due to cold weather, warm-ups, & some faster speeds, i have been more in the 38-40mpg range... still acceptable :)
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 11-17-2006, 07:44 PM   #788
swng
swng's Avatar
Under very very favorable conditions, I guess it may be possible to get better than published fuel economy. However, with the traffic conditions that I have to go through daily, I won't even think about it.
Old 11-17-2006, 08:32 PM   #789
gonzo452001
yes US gallons totaly stock except for the scan gauge there was about a 150mile trip on that tank also and i hardly ever drive over 60mph and alone most of the driving got 42.5 on the first tank use sunoco 87 regular gas i am real happy with the car
oem style foglights
Scan GaugeII
Old 11-17-2006, 08:44 PM   #790
spkrman
Drives: 1
over a 400 mile trip, and some 30-40 miles of city driving... 36.6 mpg. driving conservatively, motor only has ~1600 miles on it, 1600 after the trip that is.
Old 11-17-2006, 11:32 PM   #791
swng
swng's Avatar
You drive a lot!
Congratulations on the improvments made over what you reported the last time!
The long trip and the conservative driving style must have helped.
Old 11-18-2006, 12:04 AM   #792
spkrman
Drives: 1
Originally Posted by swng
You drive a lot!
yep, mileage is also improving as motor continues to break in, first tank was approx 32mpg driving conservatively.
The past few weeks have been sorta abnormal - lots more driving than usual. Even though i've done over 1500 miles in the last week, its more than likely that I won't go over 12k over the next year. Although, a trip to NY is coming up... 1600 more miles lol.
