#19 |
There's no fuse in the other place that it would be for a certain config of sedan, so that must be it. Did you pull it and check it closely (ideally with an ohm meter)?
#20 | |
USAF_SrA_E-4
No, But when a fuse goes out it brakes and that fuse its still new
#21 |
Check the HAZ fuse as well - It is in the under hood fuse box on the driver's side.
#22 | |
USAF_SrA_E-4
Ohh Never tot of dat
#23 |
If you have brake lights, but not turn signal lights, the HAZ fuse would be the culprit.
#24 | |
USAF_SrA_E-4
#25 |
I don't know about down your way, but up here I found an assortment pack of the fuses at Advance Auto Parts (for $7)
#26 | |
USAF_SrA_E-4
cool i will check there sincce i got something to return there anyways thanks a million dude
#27 | |
USAF_SrA_E-4
You know what I forgot the under the hood it actually has some spare fuses so i didnt have to buy any, Now in a difrent topic I started the car and the accelerator wasnt working at all it was wierd I shut it off and started it back up and still nothing I did it again and this time it work BUT now the Check E. Light its up
I SWEAR ITS ALWAYS SOMETHING.
#28 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
did you reinstall all the fuses you pulled and make sure they are seated correctly?
#29 | |
USAF_SrA_E-4
I sure did the light is off now but that was wierd how it didnt let me accelerate the car so its all good to GO now and this Thread can be deleted
