#37 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
Labour cost was $64... sharmota!
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#38 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Ouch that seems like a ripoff. Considering ezhacker is right ... all you have to do is undo the bumper clips, unscrew the headlight and then remove the bulb ... maybe takes 10 mins per light.
I agree though, it was pretty lame from an ease of use point of view. They make you never want to change the bulbs lol. |
#39 | |
MORDSITH
10 mins your way vs. almost an hour their way (w/ bumper removal) WTF Even more annoying is that I tried myself (and as well with the help of a more DIY-savvy friend) to do this, but could end up getting the clips off! Ugh (and we tried and tried for like 15-20 mins... those couple on each side were such little bitches to get at! ARG)
#40 |
yeah the bumper clips (not the black push pins) on the side are pain. i was scared of cracking the bumper, but force is definitely necessary to get it off.
o and i figured this route out after i took off my bumper to get to the lights ....lol
#41 | |
They follow the service manual procedure, which says to fully remove it. Theoretically flexing the bumper could cause it crack or whatever. I pulled my bumper once to change the bulbs and a second time to install fogs. Fully removing the bumper only takes 5 to 10 minutes. when I changed my bulbs I was completely done in less than 30 minutes and that included taking a bunch of picture of my car with it off and checking out all the things I could see with it off. They probably were done even quicker than that, but hit you with a minimum labor charge. |
#42 |
MORDSITH
Agreed on both parts, unfort.
#43 |
![]() ![]() Drives: Red Yaris Join Date: May 2009
Reason why all of you are having problems with the rear drums wearing out and not being properly alligned is because you guys aren't using your handbrakes when you park.
-Phil |
#44 |
I use the handbrake every single time, actually most times, thats all I use.
My rears still wore out in 63-64k miles. thats not bad. |
#45 |
The Japs always have to do things the hard way which is one of many reasons why I hate japped cars. What a stupid design.
-Phil |
#46 |
Half a Bubble Off Plumb
I agree that it's stupid, but like I said the good old 1940 Ford was far worse. Try adjusting the valves or replacing the clutch on one of those American classics.
#47 |
I don't think so ... I always use my handbreak when I park. Although I've developed drum problems around 110k km so it may have prolonged it ...
#48 | |
MORDSITH
I've use my parking break absolutely EVERY single time I've ever parked my Yaris. Absolutely. Every. Time. Jem
#49 | |
MORDSITH
#50 |
so if I told everyone that i can change the bulb out on both sides of my car with out removing anything sound crazy? thats how i did all my bulbs on my 07 and 09. I didnt find it that bigga deal... even when i did my HID conversion on both of them.
#51 |
yea but as much dielectric as toyota uses i think that you could pack a set of bearing, lube ball joints and tie rod ends lol.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
| Willing to buy : Left Headlight | hasher22 | Items for Sale by private party | 3 | 06-05-2007 03:17 AM |
