Old 07-25-2009, 04:54 PM   #163
Originally Posted by TylerJ View Post
is there one spot in the firewall where i can thread through the ECM wire from the switches and the two wires from the cluth cruise switch ? being that they are on opposite sides
There's a grommet on either side that you run the wires through. The one on the ECM side is a little easier to get to on the under hood side. The other one comes out behind the battery.
Old 07-25-2009, 06:43 PM   #164
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
What is the best way to access that grommet ? remove the glove box or is there a better way ?
TylerJ is offline   Reply With Quote
Old 07-25-2009, 07:10 PM   #165
PatrickJohnson
Drives: 2008 Yaris LB
no, it isnt' anywhere behind the glove box. in your passenger side floor, find the top edge of the carpet and pull it back (it' only attached by a couple pieces of velcro) and it exposes the grommet pretty clearly.
PatrickJohnson is offline   Reply With Quote
Old 07-25-2009, 08:52 PM   #166
TylerJ
ok so I pulled back the carpet and the grommet I see is attached to some hose that leads to the climate controls ... is this the one ?
Old 07-25-2009, 09:54 PM   #167
No, that one is for the AC condensate drain. I am not sure which on Patrick is referring to, but the one I was thinking of is the one which comes out just above the top left corner of the ECM (as you are facing it from under the hood). It comes into the cabin fairly high up behind the dash.
Old 07-26-2009, 02:28 AM   #168
tforkner
Drives: 08 liftback 5 speed
I used the a/c hose grommet for my wires. It's easy to remove and replace from the inside. I wrapped my three thin wires (5 speed here) with several turns of black electrical tape to protect them from the sheet metal and then replaced the hose and grommet around them. I just carefully removed the grommet and hose and ran the wires through the hole. I then replaced the hose and grommet in the hole. The grommet is nice and resilient and seems to fit around the wires well. I mounted the switches and resistors in an old cassette box and tucked it into the cubby hole beside the driver's right knee. See my previous post on how I mounted a clutch switch. The switch action is very light so the clutch pedal motion isn't going to break it loose, but I'm sure a good grab with pliers would be all it would take to remove the switch. I figure it will take me all of ten minutes to remove the whole system if I have to go for warranty work. The only downsides I see to this are maybe longer wires and perhaps having to crawl under the car. Now that I've done this mod, I think I could complete another installation in less than an hour. This has got to be the coolest modification (at 48 years old and about 18 cars under my belt) I've ever done-
Many thanks to those here who allowed me to do this!
tforkner is offline   Reply With Quote
Old 07-26-2009, 10:46 AM   #169
TylerJ
So if I crawl up under the passenger side dash will I be able to see it or should i remove it from the engine bay and let the light shine through to find it ?
Old 07-26-2009, 11:52 AM   #170
TylerJ
Ok now that I have the wires run into the engine bay what is the best way to make secure attachments to the ECM and the fuse box for the cruise switch, using certain connectors or splicing ?
Old 07-26-2009, 12:01 PM   #171
PatrickJohnson
the most solid (and convenient in my opinion) place to ground would be under the passenger kick panel, there is a ground bolt there where other things are grounded, you can't miss it. as for the ecm wire, the best way i think is to strip about 1/4 inch of the wire, push it through the connector, and bend the excess back into the slot in the middle of the connector. if you look at the pics earlier in this thread you will probably get what i'm saying.
Old 07-26-2009, 02:15 PM   #172
TylerJ
So I had everything soft wired in last night and it worked perfectly. When I ran all the wires today and tried it after buttoning things up nothing happened. I think my jumper for the clutch cruise switch in the fuse box got moved when I snapped the lid back on. This is the coolest thing to have cruise for so cheap.
Old 07-31-2009, 06:23 PM   #173
WDmac
Drives: Black Yaris sedan
2009 yaris sedan cruise control
Hello, I just bought a 2009 yaris sedan and wanted to put the $10 cruise on it. When I got into the bottom of the steering wheel colum, there is only 1 black wire coming out of the connector shown in CTSCOTT's diagram. Any ideas? Thanks.
WDmac is offline   Reply With Quote
Old 07-31-2009, 06:42 PM   #174
I believe that someone else found that as well. That means that the 09 Sedans are like the 07-08 liftbacks, which means that you will need to run the wire yourself from the ECM to the switches. Take a look at this thread, working your way from the end back for more details:
http://www.yarisworld.com/forums/sho...=16188&page=29
Old 07-31-2009, 06:46 PM   #175
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I havent seen anything yet I dont think, how do you remove the friggin dash, lol, I dont wanna break any clips, so can anyone post a pic with the screw and clip locations highlighted?
Old 07-31-2009, 07:03 PM   #176
WDmac
Thanks
Thanks a lot I appreciate the time you took to post all this info. Looks like you have helped a bunch of people save some money. I'll check out that thread and let you know how it goes. Thanks again
Old 08-22-2009, 01:50 PM   #177
Originally Posted by G6-R View Post
I bought a brandnew Yaris 1800 T-Sport 3 doors ( delivery date in about 2 months from now )
I have a original cruisecontrole handel from a Corolla Verso 1800 can i use it for the Yaris Cruisecontrole ?
No. For whatever reason, the European Yaris doesn't have cruise programmed into the ECM.
Old 08-29-2009, 07:56 PM   #178
julienrl
Drives: 2007 yaris
Hello, I wanted to do this but could not find the parts (even with the part numbers) for the covers\panels on the dash (so I can swap it for the normal one if I take the car in for servicing or something or want to sell the car as a trade in in the future), so I made the mirror cover one myself! It happens to be a hobby of mine to make plastic objects \ casting and molding, so if anyone needs a mirror cover, the master mold is made, and since that was the expensive part, i can make them for pretty cheap if anyone wants one for 10$ shipping anywhere included :). Takes about 24 to have one made and ready so it could be sent pretty quickly.
julienrl is offline   Reply With Quote
Old 09-02-2009, 10:08 PM   #179
taka
Drives: 2008 Sedan
Thank Scott for this DIY.
System is installed and working. Couple things I found on my 2008 Sedan: The wire is already installed between ECM pin 40 to connector AD4 under the dash. Instead of running a new wire from ECM or disassemble the dash to get to the wire from the top of AD4, I push a long pin up from the bottom of connector AD4 (pin 9) for wire connection to the switches.
My two spring loaded off toggle switches are mounted onto a existing blanking hole located beside the park brake handle. Toggle switches operation are: System enable/disable on each toggle and Set/Coast (when held). Sorry I would have posted photo of the installation if and when I find out how to.
taka is offline   Reply With Quote
Old 10-06-2009, 09:36 PM   #180
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
2010 US Yaris 5doorHB, confirmed
I just did post 1 to my 2010 yaris and it works perfectly. I made my own switchbox and will mount near the handbrake.
edit: I just found my new permanent switch. I will get this in the mail, then
cut off the control box I have now, and mount this in the empty switch slot
next to my stereo AUX input.
super sano install for the Yaris. keyboard sized 2-axis momentary joystick
http://www.alliedelec.com/search/pro...px?SKU=9485541
127.0.0.1 is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
