#37 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
no side airbags....
so is the resistor method works on the non side airbags yaris ? and how ? thank you |
#38 |
There are two different purposes to the resistors:
The 3 ohm ones are used to fool the Center Airbag Sensor Assembly into thinking that the side airbags are still present. The 10K and 470 ohm resistors are to fool the Occupant Classification ECU into thinking that the four passenger seat Occupant Classification Sensors are present and are indicating that the seat is empty or has an adult sitting there. This thread shows the idea behind the OCS bypass: http://www.yarisworld.com/forums/sho...1&postcount=26 |
#39 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Seats are here! Let the games begin!
#40 |
1st Play - Remove the passenger seat.
Leave the Occupant classification ECU connected. Disconnect the four occupant classification sensors (on the four corners of the seat). Disconnect the side airbag (yellow connector next to the OC ECU). When you get the seat out, take some pictures of the bottom of the seat, specifically of the sensors and how they are mounted. |
#41 |
#42 |
#43 |
#44 |
#45 |
#46 |
This is where I'm at so far
#47 |
Very good. I would like to see behind the metal shield, if you can get that angle. I want to see how the sensors are mounted between the seat and the rail. (just brainstorming on how to keep the sensors, like the person in the other post did).
#48 |
Looks like the metal shield is welded in place...
#49 |
#50 |
#51 |
The sensors are attached to the rail with a torx screw from the outside, or so it seems
#52 |
It looks like you'd have to physically remove the seat from the frame to get to at least one of these screws
#53 |
By meatal shield, I meant this guy (with the 060). The sensor is behind him:
#54 |
Slowy getting there
I can't wait to see them installed
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| FS: Recaro Pole Position Racing Seats (black) -- socal | 03Z33 | Items for Sale by private party | 13 | 12-07-2008 05:08 PM |
| sparco seats and pedals (pics) | turboyaris | Cosmetic Modifications (Exterior/Interior) | 18 | 09-05-2007 02:43 AM |
| Sport / Racing seats worth the while? | mikeukrainetz | Cosmetic Modifications (Exterior/Interior) | 10 | 11-19-2006 01:17 PM |
| Yaris Liftback Seats | artyin | General Yaris / Vitz Discussion | 3 | 04-30-2006 04:07 PM |
