#19 |
but how would the turning be up front if i rolled the fenders? Still rubbing?
#20 |
やりすぎだ~
Rolling the fenders would give you clearance on the top part of your fender, but if the wheel is too big in diameter the edge of the fender where it meets the bumper may rub when you turn, but judging from some Yaris here with 18" rims, there doesn't seem to be any problems... yet?
#21 |
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
turning full wheel lock would be the only issue but that would happen rarely (u-turns...etc), the TRD wheels are 18x7.5 et42 so by rolling the fender and a little camber you will have no poke what so ever with the 18's you want.
#22 |
アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
I was eye out some 18x8 but was worried about rub. But I have NFs, I read somewhere that someone had 18 with NFs and had no rub. I just dont know how wide it was. Anyone think it will be a problem?
#23 |
やりすぎだ~
18x8 - depending on the offset. +42 to +45 would still be OK I think.
#24 |
アキバ製
offset is +40 ><;;
#25 |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
it really depends on tire choice.
a 205 at +40mm offset and a 8" wheel will have less fitment issues then a 225 at +45mm offset on a 7.5" wheel. you can run a 205 at +35mm in the front and the tire is pretty flush with some camber. there isn't alot of fender to "roll" on a Yaris Hatch, you'll be pulling the fender. also i'd suggest massaging the fender lines in the front and the bumper attachment points in the rear. remember to run "aggressive" fitments you have to be ready to do the work to make them fit. These aren't "bolt-on" per say. |
#26 |
やりすぎだ~
Don't worry Taiyaki +40 is not far from +42. Like Penguin Garage said, tire size also makes a difference.
#27 |
アキバ製
Its has 215/35's
So what do you think guys? will it work without rub (or not that much rub) |
#28 |
Apexing Egg!!
I have a 15x7 +25 wheel offset. there was NO rubbing. I installed 10 mm PG spacers (making the wheel an effective 15x7 +15) and there is now rubbing.
the 9" +35 wheel extends 15mm more than the 15x7 +25 wheel, so it will rub. the 7.5" +38 wheel is 7mm closer to the body of the car than the 15x7 +25 thus it will NOT rub.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#29 |
![]() ![]() Drives: 2009 Yaris RS 5-door Join Date: Dec 2008
Have you seen my thread, I got xxr 504's 18x8 +32 offset all around as this is the only size available in this wheel. I believe the lip is a gigantic 3.5" all wrapped in 215/35's. The back sits perfectly flush for my liking with a little rubbing when going over bumps at faster speeds, the front would fit better with a +35 offset probably as it sticks out beyond the fender a 1/4 of an inch or so, it does not rub at all. Also i would have liked to have gone with 225/35 tires to protect the lip of the rim better however i'm positive i would have encountered alot of rubbing issues. All this dropped on trd's 1.2 all around. So to sum up I think any wheel/tire combo bigger or wider than this you will for sure have major rubbing issues without fender modification. Hope this helps.
http://www.yarisworld.com/forums/showthread.php?t=20273 |
#30 | |
Apexing Egg!!
so the maximum offset is somewhere between 15x7 +25 to +30, or with an 8, it is about +33 to +38.
#31 | |
アキバ製
#32 |
Lost
Drives: Toyota ist Join Date: Sep 2009
well peterpoop what did you end up doing? i'm curious as i was debating with 17 or 18's and of course not going for the power direction just straight looks since the car only goes from home to work on all residential areas. but all in all it's always the tires that are the cause of rubbing. lol
#33 |
hey. well i ended up saying "screw it" and I never got the wheels. however, i did find wheels that i wanted to get, but they weren't 9" wide or even 8". They were going to be 18 x 7.5" +42 with a 2.25" lip. But yah, sorry, no helpful information here.
#34 |
Lost
no problems. maybe i'll try put on my 8.5's when i finally order my yaris and see how it goes. ;)
#35 |
That'd be nice. I hope it fits. I don't think anyone is running a 8.5" wide wheel.
#36 |
Lost
just curious what is the widest anyone is using.
| 16x7 +38mm front, 16x8 +0 rear WILL IT FIT? | wildmongoose26 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 02-23-2014 12:04 PM |
| How Wide can I go? | Sabretooth | Cosmetic Modifications (Exterior/Interior) | 4 | 12-16-2008 05:36 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 09:30 PM |
