Old 08-08-2009, 10:25 PM   #109
MGargano
Drives: 2009 Yaris Hatchback
You could try it as-is to see if we clear the code 32 and have the passenger air bag on light.
Roger that. How long should I leave the battery disconnected?
Old 08-08-2009, 10:31 PM   #110
5 minutes should be enough.
Old 08-08-2009, 10:36 PM   #111
MGargano
Should I jump the OBDII ports again? Or just turn the ignition to 'on' and check the indicators?
Old 08-08-2009, 10:43 PM   #112
Power it up once to see, and then power off, jump and read the flashes. Now hopefully just codes 55 and 56 come up.
Old 08-08-2009, 10:54 PM   #113
MGargano
No good. SRS, passenger airbag 'off', and passenger seat belt indicators still lit. The jump showed the same 32, 55, & 56 codes
Old 08-08-2009, 11:02 PM   #114
OK. Do you have a multimeter to measure the voltage?
Old 08-08-2009, 11:09 PM   #115
MGargano
Rock n' Roll
Old 08-08-2009, 11:10 PM   #116
MGargano
Just tell me what I'm doing here... it's been forever since I've used this thing lol
Old 08-08-2009, 11:13 PM   #117
Probes are in the right hole. Switch it to VDC 20. Touch the black lead to pin 3 and the red to 1 and then 3.
Old 08-08-2009, 11:16 PM   #118
MGargano
Roger. We're talking about one of the four weight sensors, right?
Old 08-08-2009, 11:23 PM   #119
Correct
Old 08-08-2009, 11:25 PM   #120
MGargano
Ok with the meter on VDC 20 I'm getting zero on everything. WTF?
Old 08-08-2009, 11:26 PM   #121
You have to have the ignition on.
Old 08-08-2009, 11:26 PM   #122
MGargano
The ignition is on, for the record
Old 08-08-2009, 11:31 PM   #123
MGargano
I just tried a different sensor, still nothing...
Old 08-08-2009, 11:32 PM   #124
Hmmm. Measure the voltage between the battery posts to make sure the meter is working.
Old 08-08-2009, 11:36 PM   #125
MGargano
That's working. Meter measure 12.55 or so volts
Old 08-08-2009, 11:40 PM   #126
OK. Check the ECU-B fuse under the hood.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 06:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 03:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 02:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 05:07 PM
