Old 08-10-2009, 10:56 PM   #19
MGargano
Drives: 2009 Yaris Hatchback
Then again, I am still waiting for those 3 ohm resistors...
Old 08-10-2009, 11:09 PM   #20
There you go. Abusing your car's electrical systems becomes addictive.
Old 08-10-2009, 11:14 PM   #21
MGargano
Lol so I'm seeing. I put the OEM cluster back in tonight. How long do you figure I should leave it in?
PS- resistors shipped today.
Old 08-10-2009, 11:37 PM   #22
auxmike
auxmike's Avatar
This is a real cool thread!
I have the scanguage as a tach in my car, but I'd love a real tach too...
Old 08-10-2009, 11:40 PM   #23
If this has any chance of working, I'd say drive around tomorrow and then put the new one back in tomorrow night (with the battery disconnected).
Old 08-11-2009, 12:20 AM   #24
ryota
Dry Bones
ryota's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to ryota
i'm not sure if this would work in any way or not. but my old car if you disconnected the - part of the battery, then turned the key like you were going to turn the car on, and left it in that position for a few minutes it would "reset" the ECU. this is how i got my check engine light to go off before an inspection a few times. maybe resetting it will cause it to recognize the new cluster as what is stored in the ECU's memory from the old cluster. just a shot in the dark, but you never know.
Ryota
ryota is offline   Reply With Quote
Old 08-11-2009, 07:47 AM   #25
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
I'd say go for it Mike!
Nothing to fear but fear itself. As we used to joke when I was in the Army- "What could possibly go wrong?"
Lewis is offline   Reply With Quote
Old 08-11-2009, 07:08 PM   #26
Lewis
Lewis's Avatar
correction - it will NOT be me- at least for awhile
junkyard sent cluster that did not have a tach- i guess they figure some folks won't go to the trouble of a return
so the hunt continues- anyone with a lead on a hatch cluster with a tach and abs light- please let me know
what a bummer!
Old 08-11-2009, 07:14 PM   #27
MGargano
MGargano - Here's another idea: Put your old cluster back in (without disconnecting the battery). Drive around for a little while with it in. Then, disconnect the battery, re-install the new one, cross your finger, and power it back up.
Unfortunately, this did not work. The mileage in the new cluster remained the same after disconnecting the battery
Old 08-11-2009, 07:17 PM   #28
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
There are so many different threads on this. Can we just combine them all and sticky this since it seems to be such a hot topic?
Also, what kind of cluster would I have to search for to get the one that walterokus used? I like how it's the base model colors and not the orange S model colors.
Old 08-11-2009, 08:33 PM   #29
Lewis
Lewis's Avatar
well Mike- at least according to CT you have the option of getting the dealer to correct it-
Mike I've been losing my mind trying to find the part- how were you so lucky?
Old 08-11-2009, 09:57 PM   #30
Out of curiosity, when you put your old one back in last night, did it read what it read before the great swap?
Lewis, how about trying the battery disconnected swap (in the name of science) before you return the wrong one?
By the way, last night I was doing some research on the parts that are going to be in the wrecked Yaris that I am picking up on Thursday. It is an 08, built in 08/2007. In the EPC I noticed that there was a bulletin (dated August 2, 2007) attached to the speedometer info. This is the first time that I've run into an attached bulletin when looking up parts. In the bulletin it says:
Eligible Parts
Programmed Digital Odometer replacement part numbers for Toyota and Scion vehicles are listed on the last two pages of this bulletin. Odometers should be ordered to be programmed to read the vehicle’s actual indicated mileage at the time of odometer replacement and must be ordered directly from the listed vendor (Denso or Yazaki)
In the Yaris section at the end it references the following part numbers:
83800-52B70
83800-52C70
83800-52E70
83800-52E80
83800-52E90
83800-52F00
83800-52F10
83800-52L00
Old 08-11-2009, 11:01 PM   #31
MGargano
Mike I've been losing my find trying to find the part- how were you so lucky?
I just went to Google and typed in 'junkyards' and filled out forms on a few of the pages that popped up. Most of the places got back to me within 24 hours and quite a few of them had the part in stock. Just be prepared to spend at least $200. Mine was $225 with 1,100 miles on it from yard4.com
Old 08-11-2009, 11:04 PM   #32
MGargano
Yes
Old 08-11-2009, 11:07 PM   #33
MGargano
Try Thomas at FindAPartNow @ 717-214-4566. When I called at the end of July, he had one available for $283 + $15 shipping. Most places will try to direct you to someone else if they don't have the part themselves. That's how I got the number for yard4.com and ended up getting a near-new cluster for so cheap.
Old 08-12-2009, 12:22 AM   #34
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i typed the right part number in the other thread btw. ill try and find it
Old 08-12-2009, 12:26 AM   #35
mikenacarato
SIPNDEW
Drives: 15 STI
TOY83800-52N71
Old 08-12-2009, 07:49 AM   #36
Lewis
Lewis's Avatar
Just kidding but Mike with 1,100 miles on it why change it?
Too late to try the experiment CT- I've already returned it.
Thanks for the tips Mike- the quest continues- I thought that something was wrong with the price of $125 btw as the going rate for what we need seems to be higher.
Been looking at eBay- to no avail - just speedos and sedan clusters with tachs the last few weeks.
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 05:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 03:40 AM
