![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Technical question about bigger injectors
This question is fuel economy related but I wasn't sure if the people in the FE forum were very technical.
If you swap out the stock injectors for bigger ones AND during normal driving you stay in closed loop mode... i.e. wideband air/fuel mixture is normal at 14.7... are you getting the same gas milage as if you had stock injectors? My guess is yes. If the ECU is able to maintain an AFR of 14.7, it is metering back the gasoline to the same flow as the stock injectors. The reason I ask is whether one can trust their data logger or ScanGauge so long as the AFR stays at 14.7. No boosted driving is involved during this gas milage run.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
yes it's ALMOST the same. If the air/fuel ratio is the same and the amount of air is the same, then the fuel used is the same.
However, as injectors get bigger (for the same purpose) the resolution goes down. My 632cc injectors are at a VERY low duty cycle when not in boost, so I am using up some extra gas because of that.
| 1zz injectors suit the S/C just fine | LtNoogie | Forced Induction Forum | 51 | 04-30-2016 10:11 AM |
| Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? | trini_per4mance | Forced Induction Forum | 19 | 05-06-2009 01:18 PM |
| bigger injectors? | xxae07xx | Performance Modifications | 6 | 12-31-2008 05:04 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Technical Question for the Suspension Gurus | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-21-2007 11:31 PM |
