![]() Drives: Yaris LB Coupe Join Date: Aug 2009
tire sizes
hey what tire size do you guys recommend for me to get..its the 15" SSR MKII-Rs, 4x100, 15x6.5...
Team Praxis ...Setting the Standards... |
![]() Drives: Yaris Join Date: Dec 2008
You can try 195/55/R15 or if you dont mind heavier tyres but more contact on the road, can get 205/55/R15 which im using now.
cool thanks, apreciate it
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
The offset / desired stance will determine what tire size you need . If the offset is higher than say +30 i'd say 205/55 or if the offset is lower than +20 go with a 195/55 for a slight tire stretch/ more fender clearence...
"Stealth Runner"
yea itll be between a 195 or 205 for width but sidewall should always stay at 55 if you want to run close to oem sidewall sizing and keep your speedo relatively accurate
fyi: 16'' wheels have a 50 sidewall 17'' has a 45 sidewall 18'' has a 40 |
#6 | |
205 55 15 and 225 50 15 are about the same height.
15 x 6.5? Depends on the wheel offset and any suspension mods. Most common tyre sizes include: 205/50/15; 195/55/15; and 205/55/15.
"Stealth Runner"
![]() ![]() Drives: 08 silver streak mica LB Join Date: Oct 2008
it also depends on what youre looking for? looks, performance, daily driving? im going for looks on my 15x6.5's that are coming in and im thinking of going with 195/45/15.
Shut your fricken suck!!!
Anyone here ever run a 15x6.5 wheel on 205/50 tire? What did you think? Once again, Im looking at getting some new wheels.
Im using a 15x6.5 wheel with tire size 205/55/R15 and they are perfect, i guess it should not be much difference from 205/50/R15, jus alittle more bumpy.
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 03:00 PM |
| Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-16-2011 07:29 AM |
| Replacement Tire Sizes | Sailr303 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 06-10-2009 09:40 AM |
| Tire diameter list | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 06-04-2007 05:03 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
