Old 08-16-2009, 02:37 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Disable beep when driver door open and key in ignition
Did anyone write a DIY on this subject before? I don't like this feature at all, since I like to keep the door open and listen to my stereo while doing some work on the car, so the beeping drives me up the walls...
Does anyone know how to turn it off/disable it elegantly?
fmicle is offline   Reply With Quote
Old 08-16-2009, 02:50 PM   #2
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
I would love to disable that alarm as well...
Old 08-16-2009, 11:00 PM   #3
Here's an easy method - Unplug the door switch connectors. If you pop the lower pillar cover, the switch connector is right there. Unplug it and the beep goes away. I removed the doors from the wrecked Yaris and the beeping was driving me nuts. I popped off the connectors and my sanity returned.
Old 08-18-2009, 12:46 AM   #4
fmicle
fmicle's Avatar
Hmm, true, but that would also disable the red door light on the dashboard, wouldn't it? I'd still like to know if the door is not closed properly, I just don't want to HEAR it
Old 08-18-2009, 07:06 AM   #5
In that case, you'd have to open the cluster and remove the piezo beeper.
Old 08-18-2009, 07:46 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
But then you wouldn't get the warning if you've left your headlights switched on.
This is a valued feature for me as parts of the year I leave home in the dark and arrive at the office in daylight, often neglecting to switch off my lights. The beeper was delayed in my past ride (Talon) due to the turbo timer. I needed to use the jumper cables more often than I'd have cared to.
Old 08-18-2009, 07:59 AM   #7
In that case, do my headlights off with Key mod:
http://www.yarisworld.com/forums/sho...diy+headlights
Old 05-03-2018, 05:30 PM   #8
Ike
Drives: Toyota Yaris 2007
This bugged me too for a while, but my solution was to unplug the two wire small white connector on the top of the ignition switch. No side effects except the annoying beeping gone.
Ike is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
2007 S Sedan Questions drummer4christ DIY / Maintenance / Service 5 10-24-2006 12:10 PM
Alarm Install Bones In Car Entertainment + Electronics (audio / video / alarm) 0 05-30-2006 02:25 AM
