Old 08-19-2009, 11:12 PM   #235
MGargano
Drives: 2009 Yaris Hatchback
I am measuring between the center wire (which is the signal output) and a chassis ground. I am using a needle probe, which is a very thin, sharp probe. With the waterproof connector, I am sticking it into the rubber seal around the wire.
Ok, I'll definitely give this another try tomorrow. I don't have work so I should have plenty of time to mess around.
Out of curiosity, based on what you see so far, does it look possible to turn the airbag (and seat belt light/chime) on and off with a toggle switch? Or will we have to rig something using the OEM sensors?
Old 08-19-2009, 11:22 PM   #236
I'm not sure yet. Tomorrow morning I'll take a look at the signal output with an oscilloscope.
Old 08-20-2009, 12:11 AM   #237
MGargano
I'm psyched. I have a feeling tomorrow's going to be a good day for this project.
Old 08-20-2009, 01:59 AM   #238
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
You Guy's deserve an award , soon we can all install sports seats
Old 08-20-2009, 11:57 AM   #239
MGargano
I have all four sensors clamped like this:
Airbag 'Off' light and seat belt lights are still lit. Also not reading any voltage on the center wire.
Old 08-20-2009, 01:58 PM   #240
OK. With ignition power off, try reading resistance between the center wire and either of the outside wires. That will verify if you're actually making a good connection to the wire. You should see 48K ohms between the center and either outside wire.
Old 08-20-2009, 02:07 PM   #241
MGargano
Ok. Should I keep the sensor clamped for this exercise? And I assume I'm changing the setting on the multimeter from VDC to ohms?
Old 08-20-2009, 02:12 PM   #242
Correct on VDC to ohms. Clamping is fine - It won't have any effect on the readings.
Old 08-20-2009, 02:22 PM   #243
MGargano
Which setting am I putting the multimeter to?
I got a reading each time (center to left and center to right) with the black lead on center and the red on either outside wire but I have a feeling I have the meter on the wrong setting.
Old 08-20-2009, 02:26 PM   #244
Put the meter on 200K (always go to the next highest above what you are trying to see).
Old 08-20-2009, 02:45 PM   #245
MGargano
Ok, with the meter on 200k, black lead in the center, red on either outside wire, I got 4.4 both times. I tried a few times and the numbers kept bouncing around some, but the most consistent (when I held my hands steady) was 4.4.
Old 08-20-2009, 03:07 PM   #246
OK. So right now your SRS light is off, air bag off is lit, and passenger seat belt is lit?
Try disconnecting the battery for 2 minutes, reconnecting and then measuring the voltage on the center pin to ground. for a really solid ground you might want to pop the passenger kick panel and touch the black lead to the ground bolt there.
Old 08-20-2009, 03:13 PM   #247
MGargano
No, sir. All three lights, including the SRS, are still lit.
Old 08-20-2009, 03:18 PM   #248
With the SRS, are you still seeing the DTC 32?
Old 08-20-2009, 03:23 PM   #249
MGargano
I just checked it. I now have 32, 55, & 56 again.
Old 08-20-2009, 03:30 PM   #250
You might want to check your resistors. I had trouble with mine not making great contact. I ended up shoving mine in through the wire side so they would fit tighter.
Old 08-20-2009, 03:31 PM   #251
MGargano
Ok, I'll try that. Then do the dreaded reset of the SRS ECU again?
Old 08-20-2009, 03:32 PM   #252
Here's what I've found with the oscilloscope - Every 100ms the sensors transmit a packet of data. The beginning of the packet is always the same and the latter part varies based on pressure on the sensor.
Here are two sequential data packets from the front right sensor:
Here is one packet with no weight on the sensor:
Here is one packet with enough weight on the sensor for the airbag light to be lit:
Based on this I can easily build a module to simulate the sensors (and to switch between an empty and occupied seat).
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
