Old 08-20-2009, 04:35 PM   #253
Originally Posted by MGargano View Post
Ok, I'll try that. Then do the dreaded reset of the SRS ECU again?
Oh yeah. I've gotten mighty good at doing it.
Old 08-20-2009, 04:36 PM   #254
MGargano
Drives: 2009 Yaris Hatchback
Haha! Feel like taking a road trip to Jersey and doing it for me?
Old 08-20-2009, 04:43 PM   #255
MGargano
I've got the battery disconnected now since I tried the reset and ran into the same problems I had the first time. I can't get past the first step. The SRS light is supposed to come on solid after three seconds of removing the jumper, but mine lights up as soon as the jumper is removed. There's no delay.
Old 08-20-2009, 04:46 PM   #256
I think mine comes on pretty quick as well.
Old 08-20-2009, 04:49 PM   #257
Here's another thing that keeps the simulator simple - The sensors all "speak" at the same time. Here's the front right and rear right sampled together:
Old 08-20-2009, 04:55 PM   #258
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
except for that one little piece in the middle? it splts up the 2nd to last.. i have no idea what im looking at =D
Its a Chao!!!
Old 08-20-2009, 04:56 PM   #259
MGargano
Reconnected the battery... still have codes 32, 55, & 56. I pushed the resistors in from the wire side as well. Is it possible to snip the yellow airbag connector and attach the wires directly with the resistor in between?
Old 08-20-2009, 05:12 PM   #260
MGargano
Ok, I managed to get it back to just code 32 after fiddling with the SRS resistors.
Old 08-20-2009, 05:21 PM   #261
MGargano
Try disconnecting the battery for 2 minutes, reconnecting and then measuring the voltage on the center pin to ground. for a really solid ground you might want to pop the passenger kick panel and touch the black lead to the ground bolt there.
I just tried this and registered nothing with the meter set to VDC. When I moved it to 200k ohms, it registered 6.0 between the center pin/wire and ground.
Old 08-20-2009, 05:51 PM   #262
It really looks like your OC ECU is not responding. Take a close look at all of the wiring to and from it. Look for any sign of a damaged wire.
Old 08-20-2009, 06:57 PM   #263
MGargano
I don't see any signs of damaged wiring or anything else out of the ordinary. I can't think of anything I might have done to damage it (dropping, etc) so I hate to think there's a problem with it. Should I start looking for a replacement?
Old 08-20-2009, 07:21 PM   #264
MGargano
I found an OC ECU on eBay for $69.99, but I want to make sure that's the problem before I go ahead and order it. Or have we already made that conclusion?
Old 08-20-2009, 07:34 PM   #265
Based on this I can easily build a module to simulate the sensors (and to switch between an empty and occupied seat).
How much for 50?
Old 08-20-2009, 09:11 PM   #266
It could be the module or one of the sensors. If any one is not working properly the OCS shuts down.
Why don't you ship me your module and four sensors and I'll test all of the parts out?
Old 08-20-2009, 09:13 PM   #267
How much for 50?
How much you got?
Seriously, based on how simple I believe it is, I should be able to put together a packaged module for under $50.
This weekend I should have some time to prototype it up.
Old 08-20-2009, 09:33 PM   #268
MGargano
You rock! I was going to suggest that, but I didn't want to overstep my bounds or anything. You want the OC ECU, the four wires, and four sensors? Anything else?
Old 08-20-2009, 09:44 PM   #269
No problem.
That should do it, as far as the parts go. I'll PM you my shipping address.
Old 08-20-2009, 09:49 PM   #270
MGargano
No problem.
Awesome and thanks. Worst come worst, the auction for the OC ECU doesn't end for almost 30 days so I should have plenty of time to pick it up, if need be.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 03:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 06:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 03:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 02:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 05:07 PM
