Old 09-03-2009, 11:18 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Radiator?
Does anyone make a performance radiator for the yaris? I thought I saw one from koyo but I'm not 100% sure its cooler than stock.
link
RacerFreakXXX is offline   Reply With Quote
Old 09-04-2009, 09:36 AM   #2
hatchbackkid82
Drives: .
i was looking for one too. Wasn't too sure if it was available at the time
Old 09-04-2009, 10:23 AM   #3
severous01
be-cool radiators make customs...you can give dimensions and they'll make whatever you want. it'll prob be about 800 bux tho.
Old 09-04-2009, 12:58 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
the important question is, why.
Old 09-04-2009, 03:45 PM   #5
RacerFreakXXX
JDM Fred
Well when I go turbo I plan on keeping my ac so throwing some randome radiator in there won't be an option and keeping the car cool in the summer is important. I know I can spend 500-1k on a custom one but imo its not worth it for the money.
Old 09-04-2009, 03:54 PM   #6
true, you only need it if you can't keep the coolant the correct temperature. With that said, I had one made from C&R anyway. $700 range.
The ARC one from Japan is $1400, but I suppose it would get you show points.
Old 09-04-2009, 03:56 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
i never ran hot, even in florida summer, on 12psi
stick with toyota coolant, get an oil cooler for the turbo, and call it a day. best thing you could do is put a sensor at the water pump inlet to monitor your radiator efficiency.
Old 09-04-2009, 04:03 PM   #8
RacerFreakXXX
JDM Fred
I thank you for the advice. I'm basing my build knowledge on my friends 05 greddy turbo build I helped with.
Now my real question never got answered. Is the koyo rad for the yaris just replacement or is it performance?
Old 09-04-2009, 06:17 PM   #9
never seen it. What info do you have on it? The best they could do is to make a full-width one like mine.
Old 09-04-2009, 09:25 PM   #10
RacerFreakXXX
JDM Fred
the only info i could find is in the link... and that means no info. When I check koyo's main website i cant find detailed description of their product line. Maybe i'll send them an e-mail.
Old 09-04-2009, 09:36 PM   #11
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
At that price I highly doubt it performs any better than the OEM toyota radiator. From my experience real koyo performance rads are usually 350+
Old 09-05-2009, 12:09 PM   #12
kngrsll
Apexing Egg!!
kngrsll's Avatar
you have to remember, the end goal of a larger capacity radiator is to improve cooling. well, if you know your end goal is to improve cooling, what else can you do to improve cooling efficiency without upgrading the radiator? well, there are bumper modifications to improve flow to the radiator, changing the mixture, ducting the hood and improving flow over the radiator, and probably alot more. So if you cant find the radiator you want, check out some other ways to improve the airflow. i know you can build ducting off the rear or the radiator and vent it out the hood or sides and improve your flow and cooling efficiency.
if you do some searching, you can probably find a ton of stuff along those lines.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-05-2009, 12:15 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
SPAL fan comes to mind
Old 09-05-2009, 12:55 PM   #14
^ those are good. I have two on mine.
Old 09-05-2009, 09:26 PM   #15
RacerFreakXXX
JDM Fred
I think i may just buy the radiator to see how it is, if it's only about $130 after shipping it can't be worse. A fan mod will come too, with a switch
Old 09-07-2009, 01:29 PM   #16
Giupo
Drives: Yaris
the oem radiator is very small and I have installed the koyo radiator ;)
Giupo is offline   Reply With Quote
Old 09-07-2009, 05:48 PM   #17
kngrsll
Apexing Egg!!
kngrsll's Avatar
cool, let us know how it looks and the differences!
Old 09-07-2009, 08:00 PM   #18
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Any pics of this?
Radiator hose size window_lee General Yaris / Vitz Discussion 0 03-31-2009 07:33 AM
Anyone put in a performance radiator? mrbond Performance Modifications 19 03-18-2009 11:32 PM
radiator cap question mikenacarato Cosmetic Modifications (Exterior/Interior) 5 11-24-2008 04:27 AM
Radiator Cap for HB Beau Performance Modifications 13 12-24-2006 01:13 PM
