Old 09-05-2009, 07:18 PM   #1
jaimico
Drives: yaris advance
Dual cold cathode light installation
I just got a dual cold cathode light (blue) to installed as the one toyota has under the dash, but I want to wire it to the car´s lights, any point that I could use?
jaimico is offline   Reply With Quote
Old 09-05-2009, 10:40 PM   #2
So it turns on with the interior lights or with the headlights?
Old 09-06-2009, 12:23 AM   #3
jaimico
the headlights, it has a independent switch, so i could turn on/off as I please.
Old 09-06-2009, 10:30 AM   #4
I would use the white wire in pin 13 of the headlight switch connector for +12V and the white with a black stripe wire in Pin 10 as your ground.
Old 09-07-2009, 05:32 AM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Those are also great to use as rear plate lights. You see them on the Lexus GS models.
― Thomas Paine
Old 09-07-2009, 06:08 AM   #6
IsLNdbOi
IsLNdbOi's Avatar
Been wondering if anyone has used a 4" cold cathode in place of the puny single bulb / LED for the rear plate...
Old 09-07-2009, 08:42 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The dual 4" bulbs can be used I'd imagine. Most computer supply stores sell them with ballasts for under $10. Lexus sells one bulb for $95...
― Thomas Paine
Old 09-07-2009, 09:30 AM   #8
jaimico
ok, thank guys, and yes they do come cheap if you buy them on a computer store.
I wolud like to get a red one too for the 3r brake light, and if you installed it a flasher, you can get the F1 car brake light look alike.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
2009 HB fog light installation rbell DIY / Maintenance / Service 3 06-17-2009 10:16 PM
cold Cathode wiring slvryaris In Car Entertainment + Electronics (audio / video / alarm) 6 08-21-2007 05:34 PM
