Old 09-03-2009, 09:21 PM   #1
rexseesyou
Drives: 2009 Toyota Yaris Sedan S
Optima Yellow Top Battery Install
I have a Optima Yellow Top battery from my previous car and wanted to install it in my 2009 Toyota Yaris. Unfortunately, the battery terminals are on the opposite side and don't fit. I don't really want to buy a new one as they're expensive. Does anyone know if there is any way to extend the battery cables so they fit on the terminals or anything else I can do? Thanks for the help in advance.
I believe I have the Yellow Top D34/78 and from the Optima site... it says I need the D35.
rexseesyou is offline   Reply With Quote
Old 09-03-2009, 10:05 PM   #2
goku87
goku87's Avatar
Drives: Black HB
buy an orange top. or the similar red top, and put the yellow top in the back.
bam. ur good to go for a new stereo.
goku87 is offline   Reply With Quote
Old 09-03-2009, 11:14 PM   #3
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Yes, you should be able to buy longer cables at a parts store, but what are you going to do with the "old" stock battery? They're probably good for 4-5 years, you know. I have a 2004 Ford Ranger and the original battery is still good...
Reddog99 is offline   Reply With Quote
Old 09-03-2009, 11:14 PM   #4
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Well...have you tried putting the batter in facing backwards? Lengthening the cables would probably involve cutting and splicing, unless there are purpose-made cable extenders out there. If they exist, they'd be on ebay. :)
You can probably sell your Optima for a minimal loss and buy a new one that's correct for the application. Might only end up costing you $20-$30 bucks if your Optima is relatively new and in good nick.
Old 09-03-2009, 11:17 PM   #5
ozmdd
ozmdd's Avatar
BTW -if you aren't adding significant stereo amps or a winch, there isn't much advantage to the optima. Might be worth your while to sell it and buy goodies from Garm...
Of course, no one on the forum is rocking a winch...YET!
Old 09-06-2009, 03:23 PM   #6
RedRide
RedRide's Avatar
Yeah, most (if not all) Toyotas use a #35 battery. This is an industry designation and not from Toyota.
In other words, any manufactur's #35 battery will fit.
Personally, I like Optima batteries and have one (red top) in my other car.
Did you try turning the battery around?
Old 09-07-2009, 01:06 PM   #7
jonismyname
Drives: 08 liftback 5spd
as long as it's not a combo like a 35/75 or semi universal, although they list the bci group 35, they have center posts for universality, and the 90 degree cable end for our positive won't fit... i know because i got a $100 battery for $5 and tried using it... :(
jonismyname is offline   Reply With Quote
Old 09-07-2009, 08:59 PM   #8
rexseesyou
Yeah, I'm connecting 2 amps for my sound system
Old 09-07-2009, 09:00 PM   #9
rexseesyou
And yeah, I tried putting it in backwards. I'm probably just giving it to my brother and do have to buy a new one :/
Old 09-10-2009, 02:19 PM   #10
ozmdd
ozmdd's Avatar
Tell him you'll sell him that $500 battery for a measley $150!! :)
Old 09-10-2009, 02:27 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
Can you install two batteries in a car? Maybe in the trunk?
battery, cable, install, optima, terminal
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Lightweight battery install Klink10 DIY / Maintenance / Service 11 02-28-2009 08:43 PM
Optima battery yaris9876 Performance Modifications 0 09-09-2007 07:45 PM
will Optima battery fit in Yaris? yaris9876 Performance Modifications 2 09-05-2007 10:52 PM
