Old 09-04-2009, 09:56 AM   #109
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
got her up to 310, then backed off for a better curve.
303 whp / 284 torque @ 20 psi
hi garm, congratulations and nice one! :)
noticed the correction factor ratio (tfc) is at 1.00, does it mean there isn't any correction applied to the figures? (or if there is any needed???)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 09-04-2009, 02:31 PM   #110
I don't know that, it was a chassis dyno if that means anything. I can certainly ask.
Old 09-04-2009, 10:56 PM   #111
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
total correction factor (tcf) inter your drivetrane loss % to find out actual hp
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 09-08-2009, 02:16 PM   #112
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
at 300hp thats something like what, 1hp per 7lbs... sick
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
Old 09-08-2009, 04:01 PM   #113
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
So when are we having some 1/4 mile times and track videos???
Old 09-08-2009, 06:05 PM   #114
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
no joke... i'm watching this thread just to see 1/4mi time and speed.
Old 09-10-2009, 04:50 PM   #115
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
300hp would be about 280-285hp on a dynojet. With that kind of power, the Yaris should ET in the low 12's (assuming any semblance of traction) and trap about 115mph.
You still on stock transmission? How do those long ass gears feel in boost? Also, I missed the EMS you're using...I think you converted your wiring harness over to a TC or something like that to use their AEM?
The Spectacle is offline   Reply With Quote
Old 09-10-2009, 05:37 PM   #116
Lafiro
Drives: 06 Yaris Sedan
Wow, I am amazed at the work. Way to go Garm, keep up the great work. Good stuff to rear. Can't wait to hear from you with more updates!
Old 09-10-2009, 05:49 PM   #117
I think a DynoJet (rollers) would show higher hp, not lower. That is my experience with them, anyway.
Still on stock trans, and I am liking the gears with this much power. We ripped out all factory wiring, and re-wired by hand for the AEM EMS.
Old 09-10-2009, 06:12 PM   #118
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
You can tweak a Dynojet to read anything you want within reason. Gimme an Eddy Current dyno FTW.
RUFFSTUFF is offline   Reply With Quote
Old 09-10-2009, 07:06 PM   #119
The Spectacle
Drives: 08 BSP LB
You are correct sir. I was thinking of a Dyno Dynamics and Mustang dyno's (both read low compared to DynoJets).
What kind of boost control you running? If you plan on taking it to the track, hope you got the boost by gear setup in the AEM with a MAC/AEM solenoid!
Old 09-11-2009, 01:25 AM   #120
AEM tru-boost controller/gauge. A/B settings for 13 psi/20psi. AEM solenoid.
it's just ok, I'm not thrilled with it just yet, but it does hold boost where it's supposed to be, and I did get a pretty nice power curve.
Old 09-11-2009, 02:44 AM   #121
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
videos....
Old 09-11-2009, 04:34 AM   #122
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
+1
NST Sponsored Dyno Day In Houston NonStopTuning NonStopTuning 24 10-05-2009 03:26 PM
dyno day psychopinay42 California 1 08-03-2009 04:42 AM
looking for a cheap dyno day in central tx andruboz Southwest 6 05-08-2009 06:27 PM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 08:07 AM
Dyno Day 09/29 10-2pm SoCal DuckinOut California 20 09-29-2007 04:47 PM
