Old 09-11-2009, 10:41 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
Thinking about flywheel & clutch...
I'm wondering what kinds of gains (if any) I can hope to achieve by changing the clutch and flywheel in my '09 LB. I'm not too sure what brands I should be looking at or what prices are reasonable for these parts, so I'm looking for some advice.
I'm not a racer by any means; I'm just looking to make my daily commute a little more enjoyable.
For reference, I've already installed the following:
NST crank, water pump, and alt. pulleys
NST SSK (engine bay)
TWM SSK (lower shifter lever)
AFE intake
Megan header & axle-back with custom mid-pipe
MGargano is offline   Reply With Quote
Old 09-11-2009, 11:03 PM   #2
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
There are no actual "gains'" in HP. What you will notice by installing these are quicker revs., a little harder clutch pedal, and the clutch will engage harder. As for where to get a flywheel and clutch: http://www.nonstoptuning.com/SPEC/pSpecClutch.html There are a few members on here that have actually installed these and will be able to give you a better review.
Old 09-11-2009, 11:11 PM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
i would say very little... to me, it feels like it has a fairly good clutch, and the flywheel isnt that heavy. i would use that money to get an LSD.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-12-2009, 12:13 AM   #4
MGargano
I realized after I posted that I should have clarified 'gains'. I wasn't referring to HP, just overall improvement. Thankfully you understood what I was getting at.
Old 09-12-2009, 12:49 AM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
one would think the gains would be similar to that of
the NST pullies , Considering Spec flywheel is Approx 40%
lighter than stock , check out the NST site they have the spec flywheel and clutch .
Old 09-12-2009, 12:51 AM   #6
Mouse
Drives: 2007 MX5
You're not gaining power but freeing up the power that is already there. I say do it.
Mouse is offline   Reply With Quote
Old 09-12-2009, 12:51 AM   #7
unless you're making enough power for your stock clutch to slip, it's not time yet to replace or upgrade it. (unless you just want a stiffer feel). The flywheel will give you some responsiveness and "quickness" in your acceleration.
Old 09-12-2009, 01:17 AM   #8
frownonfun
frownonfun's Avatar
+1. i have a fidanza flywheel and TRD clutch. i prefer the stiffer clutch and like cali yaris said the flywheel adds a touch more responsiveness. it gives you the feeling that it has a little more pep when shifting but it's also more of a challenge to shift smoothly. tends to jerk the car around a little more.
do i like it yeah but do i kinda wish i'd have put my money elsewhere yeah.
Old 09-12-2009, 08:13 AM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
i know alot of S2k guys use an upgraded pressure plate, stock disc, and lightened flyweel. I prefere that sort of set up, but i dont know if you get get a pressure plate without a flywheel.
On the yaris, with those mods, there is no reason to upgrade the clutch. The flywheel may be a nice mod on the other hand.
Neither with make as big a difference as an LSD though.
Old 09-12-2009, 05:46 PM   #10
NonStopTuning
Correct
And these are in stock and ready for immediate shipping.
I would recommend the SPEC Stage 2+ clutch and lightweight flywheel for the Yaris.
Good luck and have fun with your project!
MIKE @ NST
www.NonStopTuning.com
Old 09-13-2009, 01:11 AM   #11
MGargano
Is anyone running this combo that can give me some feedback as to how it performs in a daily driving situation?
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 02:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 11:08 AM
