Old 09-16-2009, 03:02 PM   #19
The Shape
Drives: 2007 Yaris Sedan
You are probably right, but just feel better leting the dealer do it.
The Shape is offline   Reply With Quote
Old 09-16-2009, 11:47 PM   #20
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
the amount of torque required to strip those M14 (or M12) threads would be in the neighborhood of 200lb/ft. i highly doubt that a person could exert that kind of force lying down under their car with a box end wrench.
torque wrench is overkill, just get the plug "tight"
I agree but you see stripped drain plugs all the time still. That's why I ALWAYS change my own oil.
Old 09-17-2009, 10:00 AM   #21
bronsin
bronsin's Avatar
Originally Posted by The Shape View Post
I am doing all the service on our Yaris these days to save cash. I am just paranoid about stripping the oil plug. Which do you think is easier to control and less likely to strip a ratchet or box end?
There are two kinds of stripping. One is rounding off the corners of the bolt so your wrench/socket spins around and around when you try to tighten/loosen it. The other involves dammaging the threads so you cant tighten them to the proper torque.
If you get a Snap On socket/wrench they are specially made and wont strip the hex. Even if the corners of the fastner are rounded it will still tighten and loosen it perfectly. Its broached to fit the middle of the flats instead of the corners. They are expensive!
Should you round the corners of the bolt you can always buy another one! And you can use a Visegrip to remove the dammaged one so you can replace it.
As for stripping the threads just take your time and snug the bolt up by hand first. It should be possible to start the bolt by hand and tighten it up to the pan with your fingers. Then it requires on about a half turn or so with the wrench/socket to tighten it.
You just need to take your time and dont hurry and exercise a little care. Ive had cars for hundreds of thousands of miles and used the same drain bolt every time! (I did strip one once!) I prefer a wrench to a socket for changeing the oil. If you can find one get a 14mm Snap On wrench because they are specially made to not to strip the nut and even work on stripped ones!
Old 09-20-2009, 01:12 PM   #22
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
the snap-on wrench type you are referring to is called a "flank drive" and yes, they do work very well.
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
Old 09-20-2009, 01:19 PM   #23
o89canucks
Mechanic from hell
o89canucks's Avatar
200ft/lbs?!?! I've stripped Dodge cummings drain plugs out at 50ft/lbs.
Old 09-20-2009, 01:34 PM   #24
YAR1S
YAR1S's Avatar
If you can get a hold of one of these it will make oil changes SOOOOOO much easier.... and NO drips! :D
-Jen <3
Old 09-21-2009, 10:09 AM   #25
R2D2
Crazy Oil Sniffer
R2D2's Avatar
YAR1S,
I had heard good things obout the Sure Drain and ended up getting one off Amazon for under 8 bucks! I had seen them in parts stores for over 20 before. I like the low profile aspect of it! I had to cross it but I ended up figuring out the Yaris takes the model SD-3 (I hope).
Have you had one long and how did you find the quality?
TIA
R2
-The Fitful One
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
