Old 09-17-2009, 12:30 AM   #19
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
http://public.me.com/n9qgs under Toyota Maintenance I have my 109K report the Silicon issued has disappeared. Dry Ridge Toyota said the Oil pump uses silicon and as the system ages you will have pieces break off and spike oil readings, so it appears this held true as everything went back to normal. Ill do my next sample between 130K and 150K. Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 09-19-2009, 04:43 PM   #20
DerFlosser
DerFlosser's Avatar
Drives: Yaris
ahh... the overhyped Mobil1!
If you don't mind me asking....what type of "underhyped" oil do you use?
DerFlosser is offline   Reply With Quote
Old 10-08-2009, 09:40 PM   #21
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Ron,
Glad to see the silicon issue is not a problem. What a phenomenal report! Your numbers are almost beyond belief! Keep rocking that Mobil 1 the Yaris loves it! Thanks for posting.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 10-09-2009, 06:11 AM   #22
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
A couple months back I got a TSB from Amsoil regarding silicon in various Toyota models and the Vibe. Enough that they recommend their EaO oil filters be changed at OEM intervals insread of the allowed 25000. If that oil pump was the cause in one csse stated earlier, the design might have commenalities.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 05:13 PM
Best tool I've found so far to remove oil filter PICS auxmike DIY / Maintenance / Service 22 11-28-2008 01:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 05:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
