Old 10-13-2009, 11:43 PM   #1
window_lee
Drives: Yaris RS 2007
Question about Spring rate
I am look for coilover since I am tired of my lowering spring. they are just not hard enough. however, there are many different types of coilover in the market and they all have different spring rate. I am just wondering if a greater spring rate in the front will give u a better handle or the other way around.
plz give me some advices
window_lee is offline   Reply With Quote
Old 10-18-2009, 10:57 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Typical FWD car (Yaris) likes higher rear spring rates to help combat the problems inherent with front wheel drive.
I'm running nearly twice as much rate in the rear vs. the front. The balance is nice. The ride quality from running 7kg/mm springs in the rear is not nice.
Old 10-20-2009, 12:17 AM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
With what shocks?
My view is that there is not much point talking about spring rates with talking about shocks at the same time. A stiff spring on a comfort orientated shock will still probably not give you the response you are after.
In saying that, I have 175 pound fronts and 220 pound rears on my rally suspension, but I can adjust the dampening from soggy soft to bone jarring hard to suit the surface.
rob323 is offline   Reply With Quote
Old 10-20-2009, 01:30 AM   #4
ddongbap
IDK what 220lbs translates to in KG, but you should always match the shock to the spring rate, and vise versa.
Old 10-20-2009, 01:37 AM   #5
rob323
220 lbs per inch = 8.66 lbs per mm = 3.93kg/mm.
(so I'm running 3.1kg/mm fronts and 3.93kg/mm rears - stupid Aussie spring manufacturers still stuck in the dark ages ).
Agreed, shock valving should be ideally matched with the spring.
Old 10-20-2009, 05:31 AM   #6
window_lee
Thanks for the answer. I am using stock shocks with Tanabe lowering spring
I think i will get the coilover which can adjust the dampening
Old 10-20-2009, 05:22 PM   #7
rob323
Just buy better shocks which are more suited to stiffer springs.
BLITZ supercharger kits IN STOCK cali yaris Micro Image 34 06-02-2012 11:31 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
