![]() Drives: 2007 Toyota Yaris Join Date: Oct 2009
Battery light stays on
I have a 2007 Yaris with 88,000 miles. For the past two months my battery light in dash stays on if I let the car sit for a day or two. After driving it for 2 or 3 days, the light goes out again and stays out unless I let it sit again for a day or two. Anyone else dealing with this? Possible causes?
Thanks |
There is a TSB that could be relevant to what you are experiencing.
I have same sort of issue periodically. Usually happens to me when there is an extreme amount of moisture in the air. Goes away after the atmosphere has dried out. http://www.etimago.com/yaris/TSB/T-E...t%20ON%20).pdf
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Not the check engine light. He would be referring to the red battery symbol. The TSB deals with an issue of corrosion in the voltage regulator on the alternator.
Thanks WeeYari, I printed the TSB and will try.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Light weight race battery. | buddyjim | Performance Modifications | 24 | 01-27-2009 08:33 PM |
| 6lb 6oz ultra light weight battery | heavystarch | Performance Modifications | 28 | 11-19-2008 06:02 PM |
