![]() Drives: 2008 Liftback/Black/5-speed MT Join Date: Sep 2009
Broken 40/60 Back / Rear Split Seat Handle / Lever
Hi,
I fold down the 40/60 split rear seats of my 2008 Yaris Liftback frequently to load and unload my musical gear and other items. I recently discovered that I had broken the lever of the right seat, which allows the seat to be pushed forward and/or folded down. The lever is held down by two screws which go down these two delicate cylindrical plastic molded openings that have a hole at their ends to give access to another pair of stronger, metallic holes located deeper in the assembly for the screws to fasten to. It appears I may have accidentally broken the lever, most likely by tossing one of my cases in when the seats were folded down and having it ram against the lower edge of the lever; therefore, forcing it upward and breaking the ends of the of two cylindrical molded areas that were fastened down by the screws. Now, the screws can't hold the lever down anymore because the openings at the ends are too big from the damage. I've tried remedying the problem to no avail, I then tried searching for either postings about a similar situation here and online to see what they may have done to fix it, again nothing, and finally I've tried looking for a replacement part, which also came up dry. I'm worried this may be more than a quick fix, as further inspection of the the lever showed that it's actually tied to two cables inside the seating assembly that control the mechanism of the seat to be moved forward or folded. So now I'm thinking this may be something I'll need to take for the dealer to look at, and possibly may have to get the entire seat replaced. Has anyone had a similar problem, and if so, how did you get it fixed? Does anyone know if it's covered by the warranty in case I need to take it to the dealer to have it fixed? I've attached some photos to show you what I'm talking about. Many Thanks. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
oh noz! :[ I hope I dont accidently do this one day...
-Jen <3 ![]() Quote:
72057-52070 dk grey, trim piece right hand seat control
wow, thanks for that!
i tried googling the part number, but nothing came up... i also tried some toyota parts sites, and again it didn't come up with anything... any suggestions? go the dealer with the number perhaps? |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
7205852010B0 is the part # for the lever. Don't think you can replace the metal part if its damaged
unless you get a new seat back frame. The lever is $27.28 from Sparks.
http://www.cardomain.com/ride/3875996 |
#6 | |
thanks |
Right side lever is 7205752010B0. I haven't replace this before since I don't have the LB but I do have the parts lists.
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Permatex makes a super strong adhesive for plastics. Much stronger than super glue. It chemically melts the surfaces together. There are several choices available. Using this stuff you might be able to rejoin the broken bits together and save your self the time and money of part replacement.
#9 | |
***UPDATE 10/30/09***
so i took the yaris over to the dealer where i bought it... after having sit around for almost 2 hours to 'verify' that it was actually broken, they said that they'll need to special order the part before repairing it, and that they'll need around 3 hours to do the repair... apparently, connecting the lever to the mechanism cables for the seat is time consuming... as long as i don't have to deal with that or pay for it i guess (warranty :p) |
| back seat | KSIbucky | General Yaris / Vitz Discussion | 10 | 05-30-2006 12:54 PM |
| rear seat in the liftback | bwhit | New YARIS Purchase Forum | 2 | 05-21-2006 06:08 PM |
