Old 11-03-2009, 07:45 AM   #199
SEALL
Drives: 08’Yaris
Maybe you should buy a USDM ECM off ebay. Then, you'll have the only Yaris in China with cruise control.
hahahaha~~~good idea!but how much the USDM ECM? and I need to change the ECU or ECM's Program? or install it directly into the in-situ and do not change anything?
SEALL is offline   Reply With Quote
Old 11-03-2009, 07:51 AM   #200
I'm not sure about the compatibility, but USDM ECMs can often be purchased for under $100 off ebay. The engine type, transmission type, ABS yes/no, and VSC yes/no are important to match when swapping ECMs. Our USDM ECMs are for 1NZFE and 2NZFE engines. I haven't noticed which engine you get over there.
Old 11-03-2009, 09:18 PM   #201
SEALL
Drives: 08’Yaris
My yaris's engine is 4ZRFE,1600cc,Super ECT 4-speed AT,ABS yes,VSC no,maybe only have the 1600cc engines of the Chinese market.
Old 11-03-2009, 10:01 PM   #202
I think you are correct. Are you able to see the part number label on your ECM?
Old 11-03-2009, 10:06 PM   #203
rtom
Drives: 2010 Yaris 3-door liftback MT
Anybody know about relevant wiring in 2010 liftbacks?
I'd like to try this on a 2010 2-door base liftback purchased in the US!
rtom is offline   Reply With Quote
Old 11-03-2009, 10:13 PM   #204
2010 is identical to 2009 for the DIY cruise mod.
Old 11-04-2009, 08:49 AM   #205
SEALL
Drives: 08’Yaris
I don't know what's the part number,I saw the lable on my ECM,there are some number on it:89661-0DA20 ; TD275100-9872 ; C90.
Old 11-04-2009, 10:18 AM   #206
89661-0DA20 is the part number. It looks like it is a China specific ECM.
Old 11-05-2009, 12:17 AM   #207
SEALL
Drives: 08’Yaris
It seems useless to put on a USDM ECM.
Old 11-05-2009, 07:03 AM   #208
Agreed. I don't think it would be compatible with your engine.
Old 11-05-2009, 08:58 AM   #209
SEALL
Drives: 08’Yaris
Although there is no success, but very grateful to you for your help,And your very pleasant exchanges.
Old 11-08-2009, 05:28 AM   #210
sabya78
Drives: Yaris
So far it looks like only US and Canada Yaris have the cruise functionality built into the ECM. In the UAE do you get European Yaris? If so, cruise is definitely not built in.
The part number on my ECM is 89661-52C00
sabya78 is offline   Reply With Quote
Old 11-08-2009, 07:55 AM   #211
I would say that there is a good chance that that ECM doesn't have cruise control, as that part number is not a USDM/CAN one and so far it appears that just ECMs for those markets have the functionality. One test that you can try is to measure the voltage on pin 40 of the ECM connector A21, with the connector in and the ignition in the ON position. If you measure +12VDC to ground on that pin, then there is a good chance that your ECM supports cruise. If you measure 0 VDC to ground, then it definitely does not.
Old 01-14-2010, 09:00 PM   #212
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
help?
Hi guys im new here , joined because im getting my yaris tomorrow and was intrigued by this mod.
Can someone show me with microsoft paint maybe, how i can wire up this switch?
http://www.alliedelec.com/search/pro...px?SKU=9485541
~mkie~
t2mike2 is offline   Reply With Quote
Old 01-14-2010, 09:17 PM   #213
t2mike2
Originally Posted by nickhjort View Post
TDB-1, to jump the switch connector, you simply put a wire from one terminal to the other (the switch plug only has 2 terminals right)? You didn't put a fuse or anything in there just in case?
Where is the switch connector ?
Old 01-14-2010, 09:31 PM   #214
~mkie~
Old 01-14-2010, 09:35 PM   #215
This thread shows the details on the clutch switch connector:
http://www.yarisworld.com/forums/showthread.php?t=23510
Old 01-15-2010, 01:16 PM   #216
t2mike2
Thanks alot dude that is VERY very helpfull, very excited im going to pick up my yaris now. I'll post pics when this mod is done.
Thanks again.
~Mike~
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
