![]() Drives: Yaris RS Join Date: Aug 2006
good brand :) let see some pics after installation, so far i am using Xetronic, anyone know if thats a resonable brand?
oooo nice
those are nice. i put a set in a buddys honda the other day. any yall know anything about the day time running like and hids. i heard that is not good on the bulb and it will burn out often.
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
I would definitely disable the DRLs if you are going with a PnP HID kit.
ChinoCharles Intake supporter. |
Check the DIY section for my How_To on disableing the DRLs.
Green is good
Have you installed them yet?
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
I wonder if this is the real BOSCH brand. As I go to the website www.boschhid.com, it is actually a Chinese company located in China, the naming of the company is a bit confusing as well.
#11 | |
Green is good
That product may be targeted for asia market so that the web is in chinese. |
I can't say with authority, but those may be as phony as a three dollar bill.
From what I can gather, a French company makes ballasts for Bosch and they look like this: ![]() ![]() You can buy OEM parts off of eBay. This guy: integra9006hid sells Denso ballasts, Phillips bulbs and a casper shield to reduce glare when you mount the rebased bulb in our stock projector housings. I ordered from him and was very pleased with what I got. I plan to install this weekend. I'm making up a custom harness so I don't fry my stock wiring. You should order D2R bulbs to reduce glare unless you plan to eventually retrofit projectors as I do - for that you need D2S. I just got these babies today but I need to find a spare set of headlight housings before I attempt the retrofit. |
Oh yeah...
for high beams I'm mounting a pair of PIAA's 004XT Xtreme White driving lights in the fog light position and I'm making my own Angel Eyes to go around them. |
#14 |
#15 | |
#16 | |
#17 |
iloveyarisRS: are you sure you bought the good HID kit?? i thought the yaris uses H4 bulbs ?
#18 |
The Denso kit that I linked to will work in a plug & play situation. The bulb has an extra groove machined into the base that holds it correctly in the included casper shield that fits in the H4 bulb space. It comes with spade plugs to plug into the stock H4 harness. That is OK for short term but you should really buy/make a new wiring harness with relays so the ballasts are powered from the battery or you will fry your wiring (or worse) over time.
Be aware that we have a switching ground setup - meaning that the positive is always on and the ground is switched on and off. It is extremely important to get the polarity correct. |
