Old 11-19-2009, 05:13 PM   #1
joeharth
Drives: 2007 Hatchback
is the yaris seat same in sedan and hatchback?
Hello does anyone know if the sedan(4door) yaris is the same as the hatchback(2-door) seat for 2007. I will buy a driver seat from a 4 door 2007 to put in a 2door 2007. Any hings appreciated.
joeharth is offline   Reply With Quote
Old 11-19-2009, 05:16 PM   #2
sedan's have height adjustment, hatches don't...otherwise they're the same - - the fabric pattern from the sedan to the hatch is completely different too
Old 11-20-2009, 12:47 AM   #3
joeharth
I guess they are different then. Thanks. i dont mind the pattern difference but now I am not sure if the airbag sensors and seat mounts are the same.
Old 11-20-2009, 01:16 AM   #4
JayTee09
4dr=FTW
JayTee09's Avatar
Drives: Yaris Sedan
My sedan has height ajdustment but mine is an 09 so I dont know if it applies
HAA HAA .... dangly parts
JayTee09 is offline   Reply With Quote
Old 11-20-2009, 02:21 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
Well the seat adjustment only has 3 settings. High higher and highest. I keep my seat adjusted on high so it feels like im in my moms minivan even though im driving a yaris.
Old 11-20-2009, 07:51 AM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Our '07 S has the same sort of seat height adjustment as the '09s. The only usable position is the lowest, which is quite high. I have to keep the steering wheel all the way up and learned a little wiggle to squeeze in and out of the car under it. I miss the taller ceiling of the Echo, which the Yaris hatchback shares.
Old 11-20-2009, 02:07 PM   #7
b_hickman11
Drives: 08 Sedan
Yours must be different than my 07 and 08. I can pull on the lever about 10 times before it tops out. Therefore equaling about 10 settings. I can drop it all the way down where it feels like you are sitting on the road(which is where I keep it) or you can raise it up where you feel like you are sitting on the roof. Or anywhere between. Usually after about 5 pulls, my head starts to hit the roof.
Old 11-22-2009, 10:28 PM   #8
b_hickman11
Drives: 08 Sedan
Actually I am going to correct myself. I went and counted how many pulls it takes until it tops out and I got a total of 19!! So thats 19 different height settings the you can adjust your sedan seat to. If you are still not able to find a setting that works for you I suggest trading in your Yaris for a bigger car.
WTT: my 07' Yaris Sedan A/T -> Yaris Hatchback FcukThis Cars for Sale by private party 0 01-20-2009 03:34 AM
Put a yaris sedan front on a yaris hatchback?? pp.sweet Cosmetic Modifications (Exterior/Interior) 24 08-21-2007 11:17 PM
Yaris Hatchback and sedan blake111887 Performance Modifications 3 03-09-2007 07:54 PM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 03:11 PM
