Old 11-15-2009, 01:44 PM   #469
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
anyone know some light and cheap rims? or a good place to get tires?
chongopants is offline   Reply With Quote
Old 11-15-2009, 03:24 PM   #470
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
define cheap? but there was a link to a miata store that sold a bunch of them somehwere. our cars can fit their wheels. Konig Helium's are a very popular choice for light wheels. Anywhere that sells tires is a decent place. I got mine at the dealership, but any decent size chain or mechanic you trust will work.
Colin Chapman disciple
Old 11-19-2009, 10:12 PM   #471
MR. CANTON
Drives: Yaris Sedan
I have TRD SPORTIVO shock and spring and well the rim is 17" x 8" wide with 235/40/17 Sumitomo HTRZ tyres
& a pimped out PUP
MR. CANTON is offline   Reply With Quote
Old 11-23-2009, 04:47 PM   #472
07blackvitz
07 Liftback
07blackvitz's Avatar
Drives: 2007 Yaris liftback black
http://c1.ac-images.myspacecdn.com/i...372a2dbed0.jpg
Here are my wheels 15x8 +15.....
07blackvitz is offline   Reply With Quote
Old 11-23-2009, 10:37 PM   #473
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Nice stance :) What size are the tires?
Old 11-24-2009, 12:46 AM   #474
07blackvitz
07 Liftback
15x8 +15 with 195/45/R15's
Old 11-24-2009, 01:14 PM   #475
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
Originally Posted by bugslife71 View Post
Here's mine:
17s Rota Destiny with 205/40 Maxxis Tires
That Rota Destiny set looks awesome!
Anybody knows the weight for each rim?
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 12-05-2009, 10:05 PM   #476
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
Got new wheels...
5zigen ZR+ 17x7 et40 bronze Tires 205/40-17...better pics to come
Old 12-05-2009, 10:20 PM   #477
YAR1S
YAR1S's Avatar
Originally Posted by contraband831 View Post
Got new wheels...
Attachment 30616
wow.... Im in love with that roof rack....
I know you sent me all the required pieces but I cant find the PM! :(
do you still have it in your outbox?? or could you shoot that to me again? I may be looking into this with xmas money!
-Jen <3
Old 12-10-2009, 12:58 PM   #478
TRD93
Drives: 2007 Yaris S sedan
Mr.Canton- whats the offset on your wheels? do they rub? looks great.
07blackvitz- thats a sick stance!
contraband831- love the 5zigens and your spoiler
Tanabe Sustec Strut Bar, TRD Sway Bar, TRD Springs, Obx Muffler, Rubbing on 17x7 et40 Bsa Rims, 215/40/17 Sunny(total crap) tires.
TRD93 is offline   Reply With Quote
Old 12-10-2009, 01:23 PM   #479
YarisSedan
Drives: 08 Yaris Sedan
& a pimped out PUP
man those rims look badass on your yaris. What brand are those
Old 12-12-2009, 02:01 PM   #480
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
YEP, some squat is needed for sure. Nice simple rims!!
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 12-12-2009, 02:57 PM   #481
ddongbap
Originally Posted by yaris07hb View Post
Before and after shots of PnutKar. Wheels are from a Mini Cooper, 42mm offset using Gorilla E/T Conical lug nuts (BMW uses studs on the Cooper). Removed the Mini logo from the center caps with a heat gun. The Toyota logo from the hubcaps would not fit within the center caps so I left them blank. Tires are Michelin Harmony, stock 185/60R15. Contemplated 195 and 205 but cost, wear, and warranty are an issue. It is my humble opinion that these wheels look very good on the car - they complement the "roundy" look nicely. Now it needs some "squat".
You mean, they use bolts. We use studs. They use bolts.
Old 12-12-2009, 11:31 PM   #482
I run a set of the same Mini rims as my Winter rims. Their lug bolts are larger diameter than our studs and the hub is 2mm wider. If you aren't running hubcentric rings (I couldn't find ones to fit), you should use lug nuts that make the wheels lugcentric. I am using lugcentric bulge conical lug nuts that I found at Jegs that have the correct taper and have a part below the taper that fills the space between our studs and the wheel:
http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Old 12-13-2009, 06:55 AM   #483
kimona
kimona's Avatar
Drives: 2014 White VITZ
The car looks great with those mini wheels. IMO, any of the Mini wheels would compliment the car.
Old 12-16-2009, 02:20 AM   #484
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I need a set... Gorilla nakes them? I think our local shop might have Gorilla brand but not Jegs.
Top pic is Jegs and bottom is Gorilla?
Old 12-16-2009, 03:19 AM   #485
YotaYaris
YotaYaris's Avatar
Huh?
Old 12-16-2009, 08:59 AM   #486
Correct. Jegs is a supplier, the manufacturer of the Jegs ones is actually Detroit Wheels.
The flare being wider than the flats on the Jegs ones makes a better fit than the gorilla ones.
