Old 11-21-2009, 04:29 AM   #1
ketchup214
Drives: 2010 yaris
2010 hid problem
hi im new to yaris world i needed some help, i just got some hid it has a high and low beams. whenever i plugged it up only the high beams worked, i heard alot of people have trouble because of DRL but i have a button to turn it off. can this be the problem to my lowbeams not working??
ketchup214 is offline   Reply With Quote
Old 11-21-2009, 09:32 AM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
If it were me I would pull the DRL module. It took me 10 minute to remove the module from my car. Easy.
Old 11-21-2009, 10:20 AM   #3
ketchup214
Drives: 2010 yaris
how do i remove the module??
Old 11-21-2009, 12:26 PM   #4
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
search the forum and good luck
jamal1984 is offline   Reply With Quote
Old 11-21-2009, 05:29 PM   #5
ketchup214
Drives: 2010 yaris
i thought i had buttton. there is no DRL button or anything
Old 11-21-2009, 05:47 PM   #6
ketchup214
Drives: 2010 yaris
i did searched it. i got the bi hid for hi n lo beams but the lows beams are still not working anybody had a problem like this?? ive tried a couple hours trying to get it to work. no luck =/
Old 11-21-2009, 05:58 PM   #7
Check out this thread:
http://www.yarisworld.com/forums/sho...isable+daytime
Old 11-21-2009, 06:20 PM   #8
ketchup214
Drives: 2010 yaris
thanks but i found out that i dont have DRL, i have a 2010 Lift back, its seems like im getting no power for the low beams, but the high beam is getting power.
Old 11-21-2009, 06:33 PM   #9
That's right - No DRLs for 2010. Where did you connect to with your HID kit?
Old 11-22-2009, 09:07 AM   #10
In the first post you mentioned a button to turn off the DRL. Is there actually one or was that button something else? The EWD's for 2010 show the headlight related wiring to be the same as prior years. They still show the DRL module, but like prior years mention it as being optional.
Old 11-22-2009, 09:45 AM   #11
i would check the wiring for the hid's....
what kind of hi/lo setup did you buy? bixenon? or halogen high beams? ballasts hooked up correctly?
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 06:50 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 07:37 PM
HID problem hex_yaris Cosmetic Modifications (Exterior/Interior) 3 01-03-2009 12:35 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
