Old 11-20-2009, 04:37 PM   #37
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'm gonna bet the primary effect in play here is the "toe curve" of the rear suspension. It's designed to be slightly toed in at the factory ride height, and as the suspension compresses in a turn, it toes in a little more for stability. This effect is all built into the rear axle assembly and the angles at which it rotates. So, by changing to the upper holes on a lowered car, you're effectively putting things back into the alignment they were designed for.
To verify this, someone should carefully measure their rear toe before and after making this change. If I'm right, you should see less static toe out after than before.
Old 11-22-2009, 11:04 AM   #38
detroiter
detroiter's Avatar
Thanks for the finding! I'm curious though, what exactly is the benefit/gain of doing this procedure? I'm not quite sure I completely get what the end result is. Also, any negatives to it?
Old 11-22-2009, 12:53 PM   #39
kngrsll
Apexing Egg!!
kngrsll's Avatar
hmm,i need an alignment, perhaps i will try this...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 11-22-2009, 02:05 PM   #40
YarisSedan
Drives: 08 Yaris Sedan
Hmmm i just had a alignment done few weeks ago. When i get a chance ill do this and get a second alignment done and see the difference and post results for you guys Ill also take a few pics more pics if no one has done it by then to make a little more detailed DIY for those who dont know exactly what we are talking about yet. GOOD FIND!
Old 11-23-2009, 06:32 PM   #41
detroiter
detroiter's Avatar
Old 11-23-2009, 06:39 PM   #42
I did it. Super easy. I put the car on jack stands at the rear jack points, used floor jacks to support the weight of the axle and keep the springs from fighting me, and removed the rear wheels, both for weight reduction and access.
Exactly how I did it also. Alignment next week, will compare to the last one I did.
Old 11-23-2009, 07:35 PM   #43
Indianspringsaz
Drives: 07 Bitchin Blue HB
Getting ready to put some DF springs on. Should I move them to the upper hole during the install? Where do you guys trust to do the alignments? I hate going to shops and have to explain to them how to do their job.
07 Yaris HB
07 Road King
06 Superduty CC
05 Scion TC
01 30' Sleekcraft HP500EFI
Your Local Amsoil Dealer
Indianspringsaz is offline   Reply With Quote
Old 11-23-2009, 08:09 PM   #44
YarisSedan
Did you hand torque it down or just hit it with a breaker bar as hard as you could? I am guessing it should be torqued to about 145ft lbs. And maybe some threadlocker for some extra insurance. I am going to do this at home on my driveway hopefully tonight. Usually i hit everything down with a impact gun but by hand i like to get torque specs to be on the safe side.
Old 11-23-2009, 08:22 PM   #45
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
that's some serious torque there ...
Originally Posted by xnamerxx
you nailed it sir.
Old 11-23-2009, 09:43 PM   #46
Loren
What?
Loren's Avatar
Those pivot bolts don't need to be super-tight. The factory manual is available online, though... look it up!
Old 11-23-2009, 10:47 PM   #47
detroiter
detroiter's Avatar
Is there some reason my question has been skipped over twice so far? Just curious.
Old 11-24-2009, 12:42 AM   #48
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
If you read above Lorens Posts
"I'm gonna bet the primary effect in play here is the "toe curve" of the rear suspension. It's designed to be slightly toed in at the factory ride height, and as the suspension compresses in a turn, it toes in a little more for stability. This effect is all built into the rear axle assembly and the angles at which it rotates. So, by changing to the upper holes on a lowered car, you're effectively putting things back into the alignment they were designed for."
And on the previous pages you'll get an idea of how it adjusts the suspension geometry
When you lower the suspension in the front you can get bump steer. There are devices to install in the front to adjust and compensate for this. This is something akin to that but in the rear suspension where you level out the torsion beam and realign the toe.
I guess an illustration would be the best way to describe this.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 11-24-2009, 02:43 AM   #49
Loren
What?
Loren's Avatar
Um, yeah. I may not have addressed you by name, but your question has been answered. Read.
Old 11-24-2009, 03:32 AM   #50
YarisSedan
I took your advice and looked it up. For those who are interested the factory spec is exactly 67 ft lbs.
Old 11-24-2009, 03:36 AM   #51
Dang, my crappy torque wrench doesn't go that high =(
Old 11-24-2009, 04:04 AM   #52
Tamago
Tamago's Avatar
Drives: ZZW30
certainly does not need to. i removed my rear axle over 5 years ago and never used a torque wrench to re-install it. "tight" worked just fine.
you nailed it sir.
Old 11-24-2009, 04:17 AM   #53
ddongbap
So whats the end end of this?
Raise the bolt location then X happens?
Idk if people think a stable rear is better for handling?
I'd assume that having a happier rear end, or a rear end with a TOE OUT setting is better for turning? That would also make the rear end feel like its gonna get in front of you, right? Ahh, Loren, help me out.
Old 11-24-2009, 04:35 AM   #54
advocate
Drives: car
I would assume then this is for the Japanese following of the car for when it's lowered and being raced? Seems easy enough for me... Drill an extra hole for people who want to race it and leave one for the stock height...
Too bad it took us forever to find it =(
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 07:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
