Old 12-14-2006, 12:52 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
ECU reprogramming
5 speed Yaris are programmed to delay the RPM's falling when shifting into the 2nd gear. Did anyone had the ECU reprogrammed to cancel this ?
hystria is offline   Reply With Quote
Old 12-14-2006, 01:00 PM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Just forget it.It's ECU is very hard to reprogramme!
Old 12-14-2006, 02:47 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i have the solution to your problem :D
by the way, all toyotas do this, all scions do this.. why would you want to do away with this feature?
Old 12-14-2006, 02:57 PM   #4
hystria
hystria's Avatar
Can't do quick shifting because of it. I'm interested what the solution could be
Old 12-14-2006, 02:59 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
what? you can't do quick shifting because of the engine staying revvd up? that makes no sense.
do you mean clutchless shifting or just "a really quick 1-2 shift" ?
Old 12-14-2006, 03:16 PM   #6
hystria
hystria's Avatar
I mean a quick 1-2 shift at low RPMs
If I depress the clutch pedal when the engine is at 2500 rpm, the RPM will take almost a second before it starts to drop. Otherwise it stays at 2500rpm for up to 1sec. even when the clutch pedal is depressed. If the clutch is dropped at 2500rpm it will be anything but smooth - as the revs will go back to something like 1500rpm in one shot
Old 12-14-2006, 06:23 PM   #7
punch
punch's Avatar
you got to stay on the gas...
punch is offline   Reply With Quote
Old 12-14-2006, 06:32 PM   #8
hystria
hystria's Avatar
I'm doing the same while in neutral. Keep the gas at 2500rpm then suddenly release it. It takes a while before the rpm starts to slow down.
Do you guys never notice this on your 5speed ?
Old 12-14-2006, 06:43 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
yeah it sounds like a technique problem dude. if you're doing quick shifts but want it to be smooth... lol, they're sorta not congruent with each other. it sounds like you want a quick shift but not accelerate at all after going into second.
anyway, the fix is a lightweight flywheel. and i have one for sale. Fidanza aluminum, 5lbs lighter than stock.
Old 12-14-2006, 07:56 PM   #10
dngz
dngz's Avatar
Drives: black yaris sedan
how much does stock weight and how much are you selling it for?
dngz is offline   Reply With Quote
Old 12-14-2006, 07:57 PM   #11
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
How much for the flywheel?
Nutzoids is offline   Reply With Quote
Old 12-14-2006, 08:34 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
$250 shipped. it's used but in perfect condition
Old 12-14-2006, 09:18 PM   #13
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Really? Why. Do you know anyone with an interface?
BTW are you greek?
DTM_Yaris is offline   Reply With Quote
HELP Plsneed ecu diag/ecu pinout vvt-i controller install jbann General Yaris / Vitz Discussion 12 11-20-2006 11:15 PM
ECU for the 1NZ-FE in the Yaris DJ_SpaRky Performance Modifications 16 08-09-2006 11:15 AM
