#19 |
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
Also about intercoolers, on a stock car without any internal modifications to the engine and low boost, there is NO need for external intercooling. It seems a bit backwards to state, but it is true.
Such little boost pressure (5-8 psi), there isn't a need for much of the hardware they try to sell you. The piping would be eliminated and throttle response would be a tad bit better. There are better ways to cool the air charge on low PSI setups. |
#20 |
such as? water/alcohol injection?
#21 |
Turbo Yaris
#22 |
Most interesting...
![]() From how much boost onward can you see a real advantage to using an intercooler? I'll be sure to follow your progress (bit of a turbo n00b), I am most likely going to go turbo next year, then use and abuse this engine till it's really dead, then swap it...
#23 |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
The VNTs in the CSX-VNT were very similar to Garrett's standard T25 but the special thing was that they featured variable nozzles - small vanes surounding the exhaust turbine. At low turbo speeds, the vanes close to decrease the volume of the housing, causing more rapid acceleration of the compressor for faster spool-up. When it was up to speed the vanes open and increase the airflow, letting the boost level rise. They also took over the function of the wastegate, so in their applications, there is no external wastegate. I'd say they're probably good for about 15 psi, but on the CSX they were set at a maximum of 12 psi. Again... it would be a bit of an involved install and you'd have to build your own controller and put in some new sensors, but it would definately be unique.
Anyway, on to the intercooler thing, at some point, the piping and the size of the intercooler will contribute more complications and lag to your setup than the intercooler is actually helping, I've seen many low psi setups where people just ditch the notion of any kind of cooling, and it works, every setup is different though, and I guess the Yaris world is just going to have to see what works best for us. |
#24 | |
Turbo Yaris
Otherwise the alky injection will create a denser mixture without all the need for complicated plumbing and additional weight to be added to the car. More importantly, these cars were not designed for large front mount intercoolers. Thus, you would be creating a problem with the airflow going to the radiator. It would block 90 percent of the incomming cool charge and may cause overheating and damge to the engine. |
#25 |
there are always custom intercooler setups as well... I've seen some pretty wicked ones, including one that sat at the bottom of the bay and got its cold air from underneath the car
#26 | |
as for a FMIC on the Yaris, a different front bumper such as the C-ONE looks like it could accomodate one.
#27 |
I dont think placement of an intercooler (provided its not huge) would be a big deal its everything else.
Curious about the intercooler not being a necessity at low boost - we have a turbo volvo that runs at 7.5psi - the lag is horrible but once it spools up it goes like shit. Without the intercooler it supposedly would be a completely different machine, less boost, more heat, more lag. Maybe someone could give a little advice on that? Its the complication / price of the FI setups thats driving me toward an engine swap.
http://www.cardomain.com/ride/2336679 |
#28 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
I've decided to hold out for whatever trd comes up with!
#29 | |
Turbo Yaris
Don't get me wrong you need intercooling, but not necessarily with a heat exchanger. A chemical cooling agent like alcohol is a much better option. |
#30 |
![]() ![]() ![]() Drives: um not a yaris but hopefully Join Date: Dec 2006
the dodge colt turbo didnt come intercooled. I was going to swap a colt turbo onto my talon with no intercooler to start with just to get into turbos.
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
| Dash Kit if interested....ebay | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 0 | 07-03-2006 10:18 AM |
