#19 |
![]() Drives: 2007 yaris 3d Join Date: Oct 2008
Assuming the line you're seeing goes from the left to right side of the screen in the middle (horizantal line in middle of screen) it sounds like the horizontal deflection circut has failed. There are many reasons this could happen, below is one of the most common causes, and it's the easiest to repair.
<Do not attempt this unless you know what you're getting into. CRT's are like a big capacitor and hold an electric charge for a long time. If you poke around in the wrong place you could shock the $#!t out of yourself even if the TV is unplugged. I am not responsible if you injure or kill yourself.> Turn the TV on it's side, and plug it in, then turn it on. With the handle end of a standard sized screwdriver, tap around on the bottom of the TV's chassis. If the picture tries to go back to normal, even for a brief moment, then the set probably has some bad soldier joints. Now, if you, or one of your friends is knowledgeable in electronics, i'd suggest opening the TV up (unplug it first obviously) and inspecting the soldier in the vacinity of the flyback transformer, and associated power supply circuts. Cracked & decayed soldier is one of the most common failures in old CRT TV's. Probably the biggest telltale sign to look for is discolorations in the main board caused by heat. Power supplies generate lots of heat, and this heat, as well as the cooling when you turn the TV off is a large contributing reason the soldier connections decay. Re-soldier any obvious bad or questionable soldier joints, put the set back together, and try it out.. |
#20 | ||
USAF_SrA_E-4
#21 |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
yeah no.....problem fixed...I'm now watchin' cable and DVD's(blu-rays are a givin') all in HD.....now if only my PS3 chargin' cable stretch a tad bit further to my bed, it'd be all good
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
| I NEED to Figure a Way to Get More Front Seat Leg Room | msmitka | General Yaris / Vitz Discussion | 25 | 09-08-2010 07:29 PM |
| Show me your pumpkins! | Orangedakota | Off-topic / Other Cars / Everything else Discussions | 14 | 10-30-2009 11:40 PM |
| Leg Room | mgraske | General Yaris / Vitz Discussion | 8 | 09-10-2009 04:53 PM |
| Leg Room | Christopher | DIY / Maintenance / Service | 13 | 08-04-2007 12:20 AM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
