Old 12-06-2009, 11:19 PM   #1
Mister Z
Drives: 08 Yaris HB
Looking to buy a new yaris hatch!!
Looking to buy a new yaris hatch. Just had a simple question. On toyota's website its not listed. But what is the curb weight difference between the 3door and 5door? Looking to decide between the two. As far as everything goes the parts are interchangeable between the 3dr and 5dr correct?
Thanks in advance
Mister Z is offline   Reply With Quote
Old 12-07-2009, 09:59 AM   #2
DevilGirl
Drives: 09 3dr LB MT
Thanks in advance
Anything involving parts for the doors will not be the same and therefore not interchangeable (different size doors).
Old 12-07-2009, 10:18 AM   #3
Just pulled out a brochure I have for the '07 model year. The difference then was a 15 pound weight increase with a 5 dr.
Old 12-07-2009, 10:20 AM   #4
+ side skirts.
Old 12-07-2009, 04:01 PM   #5
Mister Z
Drives: 08 Yaris HB
Aite koo. Thanks
Old 12-08-2009, 05:40 PM   #6
Mister Z
Drives: 08 Yaris HB
Went to a local Toyota. Got quote OTD for $17740. This is for a 2010 5-dr hatch 5spd with power package. Is this to much for the car? What price should i be looking for OTD?
Old 12-08-2009, 05:46 PM   #7
YAR1S
YAR1S's Avatar
hmmmm that seems like a lot for a 5speed.....
got the best package(power-everything)?
-Jen <3
Old 12-08-2009, 08:35 PM   #8
Mister Z
Drives: 08 Yaris HB
Jus the power door, locks, windows, etc.
This is over 60months w/1.9% APR and 2500 down. They quoted my at 254/month for 60 months. I just did the math and thats the number I got. Is it worth it? or should I try and work my way down? or should I just stick with the base model?
Old 12-08-2009, 08:40 PM   #9
advocate
Drives: car
It really depends on your needs and your personality.
Can you love the car enough to not have power locks and windows? Remember you need to reach over across the car every time you unlock it MANUALLY just to let someone in the passenger door.
You have to train all your friends to lock the door themselves whenever they get out.
etc etc.
Old 12-08-2009, 08:47 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you can't train friends to do that, i've tried. I just lock it for them after they get out, much easier, and much less repetitive.
Colin Chapman disciple
Old 12-08-2009, 10:06 PM   #11
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
2,500 down and 254 x 60 at 1.9% APR is about 16,800, not 17,740.
You can't do this math with a regular calculator.
2,500 + 254 x 60 is wrong.
It's only correct if the APR is 0%.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 12-08-2009, 10:57 PM   #12
Mister Z
Drives: 08 Yaris HB
Okay. My fault. Well as far as options go. It would just be used as a daily driver. Nothing extravagant. The whole point of me getting a yaris is the reliability and gas mileage.
Old 12-09-2009, 12:55 AM   #13
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
If it's just a daily driver, then why not just get a base model? They only go for $13K-$14K too
Old 12-09-2009, 03:43 AM   #14
specialeducator
specialeducator's Avatar
Drives: 2008 Yaris sedan
etc etc.
It's part of the little exercise I get
specialeducator is offline   Reply With Quote
Old 12-16-2009, 10:47 PM   #15
Sidicas
Drives: 2010 Toyota Yaris Hatchback
Haha, exactly...
Power door locks break / wear out and the power windows don't work well in the winter, I'd actually pay money to NOT have them.
I grew up with manual locks and windows, I don't even think about it. It's so automatic for me like flipping a light switch when you get into a room.
The only thing that bugs me on the Yaris is the rear hatch doesn't seem to have a pull cord that unlocks it from the driver's seat.. All of our Saturns have a pull cord for the gas cover and a pull cord for the trunk latch. As far as I can tell, the Yaris requires you to pull your key out of the ignition, get out of the car, and unlock / open it yourself.. Of course, I've only been on the test drive, so maybe I'm wrong. Hopefully there's a lever there somewhere that I missed..
Sidicas is offline   Reply With Quote
Old 12-16-2009, 11:10 PM   #16
why?
why?'s Avatar
Drives: Yaris LB
nope, no lever for the hatch. You have to use the key.
Old 12-16-2009, 11:21 PM   #17
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
Okay so I have the 2010 Yaris brochure and the listed weights are: 3 Door 2311/2355 5 Door 2320/2364 Sedan 2313/2346
mr9865 is offline   Reply With Quote
Old 12-17-2009, 11:45 PM   #18
Sidicas
My last car was a two door Saturn. Don't underestimate the 2-doors, they can be advantageous. Less cracks and crevices for air to leak means a cooler car in the summer and a warmer car in the winter. As the car ages, if you don't put chemicals on the rubber door seals, it will stiffen up and then start to crack.. Next thing you know, you start getting drafts of cold air in the winter and your A/C just doesn't seem to work as well no matter how many times the service guys tell you there's nothing wrong with it. The other thing that I see happen a lot on pretty much every car we've ever owned (mostly GM cars) is the rubber seals on the doors start to fall off and you have to glue 'em back on. The more doors you have, the more work it is to maintain and the more likely you're going to have a poor seal somewhere.
Don't forget, you need to keep your doors greased / oiled too. Again, more doors is more work. On my mom's car, we never really oiled the door hinges and then just looking at them recently, I noticed that the metal is grinding itself down. There's considerable wear on the door hinges and where the metal has grinded itself down, the rust is really starting to take over.
I went with a 3 DR Yaris, I pick it up on Saturday.
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 07:04 PM
What did you pay for your Yaris and what dealership did you buy from? nu2yaris Southwest 7 07-06-2007 08:25 PM
Would Americans Buy a Diesel Yaris? Would it Sell Well in North America? gabagooo General Yaris / Vitz Discussion 23 12-11-2006 10:51 AM
