Drives: 2007 Yaris Join Date: Dec 2009
Hi Everyone,
I have a 2007 Yaris with ABS, I've had for about two months now. Recently the ! light comes on (like when the parking brake is engaged) and the ABS light as well. The lights seem to go away randomly. The lights came on again tonight right after the car had been parked in a relatively warm garage, and I tested the ABS tonight on the ice, and they did not work. But the brakes are working well otherwise. The manual says to stop immediately and call the dealer which is not practical! And I notice no change in the car speed or performance. Anyone else have a similar problem? Anyone know how serious this is or if the lights can be ignored (like most warning lights!)? Thanks!!! Tom |
![]() ![]() ![]() Drives: Toyota Yaris Sedan 2009 Join Date: Sep 2009
the (!) sign means tire pressure is low...
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
I had 2001 Prius's side brake light coming on and off when the break fluid was low.
I had 2003 Corolla ABS light constantly on when both of the rear brake lights were out. But I've never had both of them on at the same time before.
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
I only got abs light on not long ago, so i changed abs sensor and then it seems go away.
I don't have " ! " on though.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Please see this very long thread regarding the issue:
http://www.yarisworld.com/forums/sho...&highlight=ABS It's a faulty speed sensor/wiring harness. Toyota should REALLY do a recall but they seem to be getting greedy. |
![]() ![]() ![]() ![]() ![]() Drives: 09' Meteorite liftback Join Date: Jul 2009
(!) = tire pressure
Most likely wheel sensor. Lot of times there is a bunch of gunk caught on the magnet. If your lucky you can pull the sensors and clean them off. Otherwise you gota take it to a shop to diagnose which one is faulty and replace it.
If you continue to ignore it when you get in panic situation and push hard on the brakes they will lock up and skid since your abs will not work when there is a error code present. |
No it dosen't!! TPMS is an entirely different symbol. In the thread that devinlamothe referred to, I found the latest post to be very interesting. It actually indicates there may be an owner addressable cure. http://www.yarisworld.com/forums/sho...&postcount=154
I don't have ABS.
![]() Wonder if the 2010's have this issue fixed?
Never take eyes off opponent - Bruce Lee |
Half a Bubble Off Plumb
Toyota's TPMS does indeed set an "idiot light" that looks like an exclamation point in parentheses.
http://a230.g.akamai.net/7/230/2320/...nitorhybrid/s/ |
well my bad then Wee i just know that (!) showed up on mine and it was the tire pressure. it went back off after we put air in the tires.i was just trying to help
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
just to clarify for everybody:
THE TPMS light looks like (notice it looks like a flat tire) >>> ![]() and the one in question looks like>>>>
thanx hilton.
#14 |
![]() ![]() Drives: 2008 White Yaris Sedan 5 speed Join Date: Oct 2008
I just had my ABS and Brake lights come on for the first time. It is snowy and brutally cold here.
#15 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Also, If I drive my yaris into a 20 foot snow bank and dent every panel, should toyota cover it?? I'm trying to figure out where the line between normal driving and abuse is. I don't think a single sensor failing after being abused through multiple winters is that bad. ABS speed sensors fail, on all cars, if you don't like it, move out of the frozen hell you live in, but stop trashing toyota. To me this whole thread, and the one you linked to are analogous to driving through a river and then saying toyotas are junk because you hydrolocked. on a side note: Honda is recalling 182,756 MY 2006-2007 Civic sedan and coupe model vehicles. The wheel speed sensor housing uses an O-ring seal to prevent leakage to or from the wheel bearing. If assembled improperly, the O-ring may not seal properly allowing water to enter the wheel bearing and eventually cause damage to the bearing, especially in areas where use of road salt is prevalent. If the driver continues to drive with this condition, it is possible for the wheel bearing to become loose, which could cause the bearing to fail. This could cause a wheel to fall off of the vehicle, possibly resulting in a crash. Dealers will inspect the rear ABS sensors and wheel bearings for damaged parts and replace them. The recall began on September 25, 2007. 07V399 |
#16 | |
Yes, speed sensors DO fail, but they SHOULD NOT fail prematurely like they are. Fact, I had my rear left sensor replaced last winter. Guess what? The SAME ONE is busted again this winter. This should NOT be happening and yes, it is Toyota's fault for not designing a better part. And no, moving is not an option, I happen to like the cold & snow. |
#17 |
![]() ![]() Drives: 2006 Yaris RS 3 door Join Date: Nov 2009
I had these two lights come on last week, and ABS didnt work during that period. Yesterday I jacked the car up, took off the rear wheels and fixed it myself - I have only a basic knowledge of fixing stuff, the most Ive done on the Yaris to date is change front rotors/pads so no expert knowledge required!
Once the wheel is off you will see a plug - the only one you will see - on the rear of the drum near the axle. A small screwdriver is needed to push the plug (gently) off the socket and hey presto....Get cleaning! I used a compressed air cleaner like one would use on a PC keyboard to clean the snow/crap out then WD40 to clean. Cleared any excess off with the air again then put the plug back. Finally a little grease on the small gap between plug and socket and wheel back on. I got in turned the key and drove off.... NO lights on.... ABS working as it should. I suggest everyone do this BEFORE going to the dealer as it will save you a fortune. It took 20 mins to do both sides and is as easy as taking off the wheel! Southern Ontario weather does cause problems to the little car, but this is a free fix... well free if you have cleaning products already in the house! If anyone wants it, PM me and ill go outside and photograph the plug area for you... But I dont know how to post it on here so ill have to email it!!! Proof its easy to do eh? |
#18 |
| Tags |
| abs, abs warning light, brake warning light |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| help help help big problem no brake lights | AND189 | DIY / Maintenance / Service | 9 | 11-26-2009 05:25 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
