It's cold in Wisconsin...
Drives: 2008 and 2009 Yaris Sedans Join Date: Nov 2009
Just ordered my Scangauge II
I'll have my scangage in tomorrow. =) Free overnight shipping is amazing. =)
I can't wait to see what kind of numbers I'll be pulling. |
Aww, didn't support a supporting vendor?
![]() you'll like the Scangauge, it's easy to read and very useful.
Sorry didn't go with the local vendor this time.
![]() Next time though. |
Do you guys sell any of the quick drain oil plugs? Or are those gimmicky?
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Learn to Relax
Fumoto FTW.
#7 | |
After you get used to the gauge a bit you might want to set the X gauge to show average mpg as the real time mpg reading is all over the place..
X gauges are a bit of a cluster f--- to set up but the average mpg setup goes like this= Quote:
mind if I ask where ya'll mounted yours?
when i had one, i put it right in front of me on the steering column.
So I got it in the mail today, and so far I love it.
Still need to mess around with it and get it fully programmed. I think I'm going to zip tie / mount it to my GPS unit. So far it seems to be fairly accurate when it comes to usage, I just need to get it calibrated and fully set before I trust it any further (not to mention do some math to make sure it's not sweet talking me). |
#11 | |
if you fill up using the exact same gas pump, parked the exact same way, and stop at the first click every time, it cannot do anything but calibrate itself correctly over 2 or 3 tanks. this may vary. preprogram it for a 2.9 offset and it'll be really close to perfect (given you do the initial setup properly) |
out of curiosity... why 2.9 offset?
because that is what my offset ended up to be and
2.9 will probably get you accurate mileage from the first tank you can choose not to set it, and it'll take 3 or 4 tanks to be sure the offset is accurate. 'cuz your first two tanks will be off, and leave you wondering. you'll prob end up at 2.9 or 3.2 anyhow if you have a 1.5 liter yaris |
I just can't find a good place to mount this damn thing....
I think I'm going to try and fasten it to the bottom of my GPS mount. That's tomorrow's task. |
Lurker supreme!
I popped off my A-pillar trim and ran it up there, under the headliner, and mounted it on top of the rear-view mirror. Not a bad spot for it... although a bit hard to read when it's bright out due to contrast.
2006 Red Blitzed RS 5-door |
put mine right on the steering wheel hump in front of the storage bin
shoe-goo and velcro strip. cable up the back side. looks like it belongs there |
I don't trust this thing till it's calibrated... but I'm averaging 30-42mpg on the highway on trips.
I set the 11gallon tank I set the 1.5 Liter engine The only puzzling thing for me was when I did a full fillup it asked me to cycle though (very slowly I might add) how much I put in the car. I assume I don't touch that and leave it at zero? The quick reference guide wasn't very helpful or specific on that. |
you tell it how much gas you put in
if it's estimate is exact and shows what you put in, don't touch it if it is off, adjust it by what you actually put in then put in the cost it is all in the user manual |
| Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! | TRD_Yaris | General Yaris / Vitz Discussion | 183 | 02-01-2017 12:18 PM |
| BDD's first mods - tach + Scangauge II | BDD | Performance Modifications | 11 | 04-29-2013 11:23 AM |
| What is the average Scangauge II offset percentage ? | 127.0.0.1 | Fuel Economy Forum | 13 | 03-05-2010 08:08 PM |
| scangauge II versions | TinyGiant | Fuel Economy Forum | 1 | 12-23-2008 12:10 PM |
| Ordered mine today... now the wait begins | boris13 | New YARIS Purchase Forum | 1 | 11-10-2006 07:40 PM |
