Old 12-22-2009, 02:49 PM   #19
Rolling the fenders means removing the liner. I've done it, it buys a little bit of clearance but not much.
Old 12-22-2009, 02:50 PM   #20
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
my situation in the rear is the tire is about flush with the edge if the car and rear bumper
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 12-22-2009, 03:01 PM   #21
you could also use those washers in the rear for a little negative camber back there.
Old 12-22-2009, 03:24 PM   #22
Arkhangel
Arkhangel's Avatar
Gonna see what happens when i install the TRD Springs
Old 12-22-2009, 04:05 PM   #23
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
, hmm, from what i remember, your shocks are non existant, making you slammed on the ground, you should probably get new shocks dude, not trying 2 me an ass, just making a suggestion
Old 12-23-2009, 09:07 PM   #24
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I am having rubbing issues as well. Too bad the tein shocks are so much money :(
Old 12-30-2009, 10:37 PM   #25
Brentorius
Drives: 07 Mazda MX5 Copper Red
I installed the Tokico blues and a 23mm rear sway today. Loads of improvement! The ride feels more "controlled" and firm over the bumps. With the trimming of the front fender liners I have 99% eliminated the rubbing. I am currently on a factory alignment and might do an slightly aggressive one soon (-1 to -1.5 camber w/ 0 toe).
I also did the rear suspension bolt relocation, and will report the rear alignment specs when I go next week.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 01-04-2011, 03:08 AM   #26
crolandiz
Drives: Yaris Sedan '08
Hi, I also have 215/45/17 and there is rubbing on the rear when I take 2-3 passengers on bumps.
Do you think it is good to roll/cut fenders? or better go to an alignment shop and get the rear camber?
What will happen when in the future I order MI Springs? Will this continue to be an issue?
crolandiz is offline   Reply With Quote
Old 01-04-2011, 11:10 AM   #27
big lo
big lo's Avatar
Drives: 2007 VIOS
Well I'm rolling on 18's with low profile tires 215/35 R18, I've been rubbing but what I did was cut the liner a bit and she is good, plus I got tokico blues and Tein spring, with only an inch of space from the tire from the fender, I was thinking about changing them but no, I love the drop and the feel.
Old 01-04-2011, 11:46 AM   #28
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
You can also TRIM the liners only where they rub, keeping the rest intact.
im not running 17's but my yaris is pretty low now. i just trimed out the middle all the way to the next front and rear clips that hold the liner in place. i am just trying to keep my CAI as clean as possible so the dirt/mud doesnt coat my filter.. ill be running 225/45/15 here soon so i will need to roll the fenders as well
Old 01-04-2011, 11:32 PM   #29
big lo
big lo's Avatar
Drives: 2007 VIOS
This will also depend if your rims are wider as well that would rubb until nothing is there
Old 01-05-2011, 01:16 AM   #30
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
tein basic damper on mine.. 2 inches in the rear 1 3/4's in the front. I rubbed to the point where the under carriage near the top front is no longer there =(
alch3miss is offline   Reply With Quote
Old 01-05-2011, 03:16 PM   #31
MUSKOKA800
MUSKOKA800's Avatar
Simply adding the Tokico damper may solve your issue on all but the deepest dips taken at speed. But, you may as will do the camber change when the dampers are installed. All it'll cost is the price of the crash bolts.
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
Rubbing botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-06-2009 03:32 PM
Dealing With Rubbing nqd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 04-24-2009 01:56 PM
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
