View Poll Results: What do you consider the best size, when considering everything?
14" 8 6.61%
15" 55 45.45%
16" 40 33.06%
17" 17 14.05%
18" 1 0.83%
Voters: 121. You may not vote on this poll
Old 12-31-2009, 05:56 AM   #19
WolfWings
WolfWings's Avatar
I'm crazy: I love running 14's here in the winter, and if I could be bothered I'd run them in the summer too if there was any decent tires for it. As it is, 15's in the summer just so I have decent tires available.
Old 12-31-2009, 06:54 AM   #20
advocate
Drives: car
You didn't include 13s!
Old 12-31-2009, 08:27 AM   #21
elmo
WFO
elmo's Avatar
Drives: 2008 hb
O.O how did you get that close to the air force one? or is it on display? HAH
I tried to even watch that plane take off at my local airport and I felt like I was being watched...it felt like every single official in the world was there at every street corner.
that is an old plane i think it is a 707 the air force 1 that the pres uses now is a 747 i think they been using 747's since regans 2nd term i could be wrong on that date
elmo is offline   Reply With Quote
Old 12-31-2009, 08:29 AM   #22
elmo
WFO
elmo's Avatar
Drives: 2008 hb
my wife is running 14" michelin harmonies on her echo very good tire
Old 12-31-2009, 02:20 PM   #23
jakota
Drives: yaris 1.33
winter tyres
Europe 2009 Yaris 1.33 L , replaced stock front summer 185/60/R15 with winter 185/65/R14; rear untouched stock 185/60/R15. Cheap solution for snow, good behavior.
jakota is offline   Reply With Quote
Old 01-01-2010, 01:14 AM   #24
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Here's why I went with 17's: I like short stiff sidewalls for better steering response, and I like bigger wheels. My wheel and tire combo is not only wider and lighter than stock, but the overall diameter is also shorter than stock for better acceleration. Win/win/win if you ask me. The only drawbacks I can think of are a greater chance of wheel damage and a slightly stiffer ride.
As far as the original question, for the best compromise between price, practicality, and performance, I would go with 16's. I was actually thinking of getting an extra set to try out.
Old 01-01-2010, 04:13 AM   #25
r3b3l
r3b3l's Avatar
Drives: 2010 Yaris 3dr liftback
I don't understand why the bad part of having 17's is that you get worse response at takeoff or worse handling, or even mpg. If you run the same rolling diameter as stock how can you get anything worse than stock performance. Even if you had a small increase in rolling diameter the worse thing that could happen is having to recalibrate the speedo right? I understand pot holes could be a problem but if you still have 4 inch walls maybe you should not drive over a road that has been hit by a clusterbomb. I mean most places have decent roads, hell I live in MS we have the most horrible roads in the union and they wouldnt cause pothole damage.
r3b3l is offline   Reply With Quote
Old 01-01-2010, 04:40 AM   #26
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
^^ It does depend on the wheel; some are really heavy.
Old 01-01-2010, 11:51 AM   #27
Kal-El
Kal-El's Avatar
The other "drawback" with 17's is the premium on tire prices while also not lasting as long. 17's for the Yaris generally only last 30K, maybe 40. While you can get 15's that last 75-90K and costs 50% less.
Old 01-06-2010, 07:50 PM   #28
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
As someone that bought his car with 17's I would prefer 15's or 16s if they are light.
Old 01-06-2010, 08:06 PM   #29
LA Yaris
Yaris323
LA Yaris's Avatar
For me I kept it with with a 5 pounds 15" wheels on the stock tires. On a 3" drop, I am happy I did that cause now with the body kit. It does not rub to much.
Old 01-06-2010, 10:22 PM   #30
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Unless you are trying to run big power i don't see any reason to go anything but 14". The tires I have surprise me every time i try a little spirited driving. Much better than stock. They just keep on holding. Plus the light weight is great as well.
Colin Chapman disciple
Old 01-07-2010, 12:04 AM   #31
XYaris
Drives: '09 Yaris LB
I run 17 inch wheels normally but this winter I put some Blizzaks on my stock wheels. I must say that I am enjoying having a sidewall a great deal. The steering response is not the same but I am seriously considering selling my 17's and going with some 15" alloys in the spring.
XYaris is offline   Reply With Quote
Old 01-07-2010, 12:24 AM   #32
supmet
Drives: 2007 4 Door Yaris
I'm seeing your wheel tire combo as 37 lbs total(15 lb rims and 22 lb tires), and stock is 33 from what I've heard. Also, as I posted before, your weight is farther out than stock, so more rotational inertia.
Old 01-07-2010, 12:28 AM   #33
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
I currently have a set of 15's and 17's and I love the look of the 17's and the comfort of the 15's. I voted for 16's because i think they will be the best of both worlds (looks and comfort). My TRD 18's filled the gap well, looked cool, but made the car sluggish and the ride was not the best.
Old 01-07-2010, 03:34 AM   #34
I have 17's, and I gotta say that I love them. However, when I get new rims, I'll be getting 16's. I really hate driving over unavoidable bumps and holes in the road, and praying that my 17's aren't bent.
Old 01-07-2010, 11:14 AM   #35
Kal-El
Kal-El's Avatar
16's are right on 15's ass now. Good race.
Old 01-07-2010, 12:05 PM   #36
r3b3l
r3b3l's Avatar
What width of tire is the best for the different sizes we are discussing? After reading the about the good and bad for the rim sizes I have decided to just stick with 15's. So whats the best tire size to go with more specifically the width of the tire.
This post is not intended to hijack the thread but augment it. :)
Xa - Yaris steering wheel jcove Cosmetic Modifications (Exterior/Interior) 1 05-09-2006 09:04 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 12:38 PM
