Old 03-08-2009, 06:41 AM   #145
MGargano
Drives: 2009 Yaris Hatchback
automatically lights up when turned on , then you can change the color to
what ever you want
Thanks!
MGargano is offline   Reply With Quote
Old 03-18-2009, 09:06 AM   #146
MGargano
Has anyone tried using the 'Blendmount' to install their Scangauge II above the rearview mirror? It looks like a pretty good idea, just not sure if it'll fit since there's not much clearance between the mirror and windshield. Their website doesn't say what vehicles it works with, so I'm curious if any Yarii owners have tried this.
http://www.blendmount.com/showthread.php?t=2
Old 03-18-2009, 12:04 PM   #147
Klink10
Klink10's Avatar
Was going to but I like you believe there will be a fitment issue. I am working on some ideas now, none of which include that.
Old 03-18-2009, 08:40 PM   #148
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
No Need i Velcro's to the roof and i won't move
Old 03-18-2009, 10:11 PM   #149
MGargano
LOL! Nice! Where were you before I wasted $45 on the Blendmount?
Old 03-20-2009, 12:46 AM   #150
MGargano
Anyone have a problem with the Scangauge saying 'Connecting...' then turning off after about a minute without giving any data? I tried all the troubleshooting FAQs in the manual, but none seem to get it working. Weird thing is, it was working fine for a week or so, until today.
Old 03-21-2009, 07:24 PM   #151
EasyDriver
Drives: 2008 Yaris Meteorite LB
Nice job...looks professional! How did you run the wiring?
I got one 2 days ago and just ran it around and under the right side of the steering column. It tucks right into a seam along that side and just stays in place (pretty well). It rests on top of the steering column and when I park it I just slide it into the left glove box.
EasyDriver is offline   Reply With Quote
Old 03-21-2009, 07:33 PM   #152
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thanks
I just tuck the wire under the edge of the roof panel then removed the A pillar cover ,and then under the dash. 5 minute job.
Old 01-09-2010, 01:10 AM   #153
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
FINALLY (as of Christmas day) the proud owner for a ScanGauge II!
Originally Posted by 60 Somethings View Post
We are considering a ScanGauge for our liftback, and I like the idea of housing in in the driver's glove box.
That's were I leave mine. Just pop open the drivers glove box while crusing when wanna have a peak. Leaving it up when wanna actively watch it dont bother me. And i like that i dont need to Permanently mount it anywhere inside (so great to have that glove box there!!)
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 01-09-2010, 01:41 AM   #154
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I copy/pasted the trouble codes for Toyota and put it on one page.
Feel free to print it out and store it in your glovebox in case you need to reference it.
(Word document file)
Old 01-09-2010, 11:54 AM   #155
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
didn't know this thread was here. cansf ambient air works on us 2010 yaris 5 door hb
127.0.0.1 is offline   Reply With Quote
Old 03-14-2010, 01:23 PM   #156
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
I've changed one of my Scanguage spots to read out TPS. How come the max is 81 (have seen 82). Is this accurate that the butterfly valve is only opening 81%, not that I think I'm missing out on some performance, but curious if by design there's no reason for it to open to 100% - or - the reading is not accurate.
FYI - I've never used a Scanguage in any other car
BuildCode is offline   Reply With Quote
Old 03-14-2010, 06:54 PM   #157
Rick
Drives: '08 Yaris LB 5M
If Toyota's firmware design is similar to Ford's (I'm guessing it is) then it's not inaccurate and also not a direct indication of throttle position. To avoid needing precision calibrated throttle position sensors ($$$), they use a % of possible measurement range. The firmware learns what % indicates closed throttle and what % indicates WOT. Individual TPS sensors don't have to be 'exactly' like each other and that makes them much cheaper to produce.
It also means that as the TPS changes slightly over the life of the component it creates no problem. The firmware adjusts for the changes.
In the Ford world 0 volts = 0% and 5 volts = 100%. The Ford TPS output doesn't go down to 0v and doesn't go up to 5v. I see 21% to 92% on my Cobra.
There is a 'normalized to 100%' proprietary extended parameter but Scangauge doesn't use it.
Rick is offline   Reply With Quote
Old 03-14-2010, 08:44 PM   #158
BuildCode
BuildCode's Avatar
cool! that's good to know, thanks for the detailed response
Old 07-03-2010, 05:56 PM   #159
Billiam
Drives: '10 White Yaris 4D LB
Anyone tried this vent mount with their Scangauge?
http://cgi.ebay.com/Car-Air-Vent-Mou...item5190dfc8a3
If you want to enjoy your car, stay off of the internet.
Old 07-04-2010, 05:16 AM   #160
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Didnt a vent mount clip come with the device?or maybe it was some other electronic gizmo,what ever it was it didnt work very well, I found a bit of velcro
was the easiest and most versatile way to mount the gauge on the dash just in front of the steering column.
Old 07-04-2010, 11:49 AM   #161
Billiam
I haven't ordered mine yet, but I don't think it comes with any mounts (maybe velcro). Anyway, I saw the windshield mount and this "vent" mount on ebay. Just wondering if someone had actual experience with this mount and Scangauge together. Our out-board vents are kinda weird, so I can see it not working too well. But if it does, it's a better solution than velcro, IMO.
Old 08-12-2010, 07:26 PM   #162
kazama82
Drives: VIOS
i notice that my odo meter is not the same as scangauge odo meter..scangauge shows faster increment compare to my car odo..anyone notice this?..for example now my car odometer at 90km, but my scangauge odo already showing 96km..
kazama82 is offline   Reply With Quote
