#19 |
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
Great, thanks mate. That's the information I was missing.
So now we wait for a lovely sunny day for me to get my hands dirty in the engine bay :) I'll keep you all posted |
#20 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
TRAC, if turned off by the mild button press, will reactivate automatically VSC, if turned off by the hard button press, will NOT reactivate automatically TRAC, if turned off by the feet and handbrake, will NOT reactivate automatically that is what techinfo.toyota.com sez about 2010 yaris |
#21 |
Sounds good. You owe us some pictures of your Yaris as well. I enjoy seeing them in their native habitats all over the world.
#22 |
![]() Drives: Blk 3door Join Date: Jan 2009
Makes me curious about the 2009 Yaris models.... going to have to do some research.
#23 |
#24 |
#25 |
so if u were to dissable VSC and TRAC (i have the switch, so i know the long hold) they will never turn on again unless the car is restarted or the switch is depressed again. and the car has no other traction control functions. i'm looking to drift and such but found with only TRAC off the independent braking still was applied (since i found out about the long hold for VSC it hasn't snowed again so haven't been able to test it)
#26 | |
techinfo says trac will come back on, if only trac was turned off |
#27 |
Ok, so I took a look at the brake actuator yesterday, a found that it's quite accessible. But it was late last night and I wasn't feel like taking out the battery. The connector really looks like A30 (quite big and without round corners like A15).
I'll try to do that dirty test with a wire during this weekend. |
#28 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
Is it possible for someone who got the switch from factory to make a picture of its back? I found some connectors under my handbrake lever and want to know if maybe i can attach the TRC/VSC switch to one of them.
#29 | |
VSC Switch.jpg |
#30 |
Thank you but no luck for me. I found this little guy but have no clue what it is used for.
#31 |
#32 |
No but maybe its prewired. "Executive" models have keyless entry here.
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 02:20 AM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 10:22 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 05:11 PM |
