Old 01-23-2010, 08:39 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
New suspension!
so i finished my new suspension set up finally! it has been in limbo for quite awhile.
last season i tracked the car using DF210's, 23 mm rear sway bar, so the spring rates were 175 lbs F and 125 lbs R. The car drove great and the balance was very good!! it needed some more spring, so i have been trying to figure out something to make that happen. i didnt want to lose the HTS's so i wouldnt consider coilovers.
so now, i am running ground control coilovers from a Honda Fit on the front with 6" 375 lbs springs, and the rear springs from the T1R Honda Fit kit, 342 lbs.
So together, the set up is 375 lbs in the Front, and 342 lbs in the Rear with the sway bar. This should give a balance very similar to the setup i used last season, but each corner is nearly 200 lbs stiffer.
After a quick drive around, it drives absolutely AMAZING!! I havent tracked it yet, so its really hard to say, but it is very flat. Cant wait to put the car around a road course, maybe pass some more corvettes and vipers
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 01-23-2010, 09:07 PM   #2
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
How much did your new set up cost you?
marlondog is offline   Reply With Quote
Old 01-23-2010, 09:35 PM   #3
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Nicely done! Gives us more options. Time to change your sig? hehe
Old 01-23-2010, 09:55 PM   #4
can't remember the conversion to k, anyone?
Old 01-23-2010, 09:56 PM   #5
and that installed with no mods, front and rear?
Old 01-23-2010, 10:04 PM   #6
justjesus
justjesus's Avatar
375* 0.0179 = 6.7125
342* " " = 6.1218
Old 01-23-2010, 10:10 PM   #7
ddongbap
Can those shocks keep up with 6kg springs?
Old 01-24-2010, 09:54 AM   #8
kngrsll
Apexing Egg!!
kngrsll's Avatar
i already had the sway bar, the full set of Fit springs were $120-130 i cant remember, and the Ground Controls were $400 or so. So, definitely not cheap, but that wasnt the point. the point is to try things out and find new options, i like to explore options
Yes, time to do that, haha
everything installed with no modifications. i trimmed a small segment of rear spring off to lower the car about a half inch, it was under half a coil and it was one of the "dead" coils. now the front and rear sit even.
The engineer at Tokico said the shocks would handle 500 lbs easily. I can tell you, driving around town, the shocks are not taxed at all. In fact, the car is more comfortable than before. I think because the front shocks are not bottoming out constantly!
Old 01-24-2010, 10:53 AM   #9
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
sounds nice! how's the ride around town with bumps? is the drop more or less compared to the df's?
Old 01-24-2010, 11:05 AM   #10
kngrsll
Apexing Egg!!
kngrsll's Avatar
thats the wierd thing, the ride is SO MUCH better! bumps, everything. i think its bc the fronts are not bottoming out anymore.
Old 01-26-2010, 01:25 PM   #11
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
What an awesome find. Thank you for sharing. Definitely post up a whole parts list and opinions once you track the car!
Old 01-26-2010, 02:39 PM   #12
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah sure thing... i tell ya what, this set up is incredible. the car is going to be FAST. its like a mini type R
so as of now, my mods are:
Power:
DC Header
Pulley
Chassis:
Tokico HTS shocks
Ground Control Honda Fit front coilovers (375 lbs/6.6 kg)
T1R Honda Fit rear springs (342 lbs/6.1 kg)
23mm rear sway bar from UR
Other:
TRD 2-way clutch LSD
Cobra Suzuka seat
Team Dynamic wheels 15x7 +25
Dunlop Direzza star specs 195/55/15
Carbotech brakes xp10's
Future:
What i would really like is some rear brakes next, and the chassis will be done. The only other thing i could want is a roll bar. Then, it may need some power, but thats starting to get pretty expensive. If the car drives as good as i think it will on a track, i think it would be totally worth it. another 50 hp would be solid... so a blitz supercharger, intake, and a good tune would probably do the trick. as it was before, without the LSD and stiffer springs, it was a shocker at the track, so i cant wait to see it now :)
Old 01-26-2010, 02:47 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
I still can't believe Honda Fit suspension bolts up to a Yaris. That's crazy.
coilover sleeves dont' bolt up.. they slip on ;)
Old 01-26-2010, 03:00 PM   #14
kngrsll
Apexing Egg!!
kngrsll's Avatar
seriously, there are probably a hundred other applications taht fit. my friends SE-R ones fit too.
Old 01-28-2010, 05:58 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
hmm and a heck of a lot cheaper than coilovers too. You said you cut the rear just for the looks, but it wasn't necessary? I wonder what else would fit.
Colin Chapman disciple
Old 01-31-2010, 11:43 PM   #16
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
that is in-f*cking-credible... I was even looking around for GC coilovers for my yaris today.
has anyone come up with a solution to make the rear adjustable?... or can you use the rear honda fit sleve/spring combo?
e.g this kit?
http://www.ground-control-store.com/...hp/II=750/CA=5
mick.wheelz is offline   Reply With Quote
Old 02-01-2010, 05:02 PM   #17
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah, that kit... the problem with the rear, is that the rear spring perch ends up too high. you may be able to use if you can get someone to send you some perches made for the yaris, like tein or megan.
Old 02-01-2010, 07:42 PM   #18
mick.wheelz
I could probably get some machined up if i had a template or one to copy... anyone want to help out here?
Would the actual springs supplied for the rear suit?
also,would you be able to take a few more photos of the whole setup?
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Noobie suspension question?? Richie76 Australia 6 12-27-2009 09:27 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
Tough Suspension YarTrek General Yaris / Vitz Discussion 6 01-01-2009 08:05 AM
