Old 01-27-2010, 12:51 PM   #1
DenverDave
Drives: 2010 Hatchback
Fluctuating RPM
After the engine is warmed up and in idle the RPM continuously cycles between 400 and 600. It will be running smooth at 600, then the RPM drops to 400, where it runs rough for a few seconds, then the RPM increases to 600 where it runs smooth for a few seconds, etc. It has done this since the car was new. Is this normal?
DenverDave is offline   Reply With Quote
Old 01-27-2010, 03:53 PM   #2
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
What engine do you own?
Could you set the idling to 800-1000. 600rpm seems too low for me
" It has done this since the car was new " Why don't you ask the dealer that sold you the car in the first place?
Old 01-27-2010, 04:24 PM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
It does this when charging or under load with heater/ ac or radio headlifghts. Normal but suboptimal. AFIK nothing correctable.
TheSilkySmooth is offline   Reply With Quote
Old 01-27-2010, 10:04 PM   #4
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
It's just how toyota tunes these cars to get as much gas mileage as possible. It is normal.
Old 01-27-2010, 10:34 PM   #5
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Normal, mine does it too from time to time.
Old 01-28-2010, 10:13 AM   #6
DenverDave
OK, I thought it could be normal. It's like the engine is seeking to burn as little gas as possible.
Old 01-28-2010, 10:49 AM   #7
yaris2010RS
yaris2010RS's Avatar
i have posted a similar problem also. mine idles at 500 rpm then will jump to 800rpm (ish) and then drop down. at first thought it was the a/c kicking in so i turned everything off and it still does it. look under the hood and watch, i noticed as soon as it jumps up the rpm the fan will kick in and when it goes back down the fan turns off.....
Old 02-05-2010, 03:45 PM   #8
TheSilkySmooth
Operating with any partial or Defrost On setting on air director with fan at 1 or higher = AC on; regardless of ac switch on or not. I think.
Old 02-06-2010, 01:54 PM   #9
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
^^ +2
Old 02-07-2010, 09:53 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
mine has always done it. it's normal.
Colin Chapman disciple
Old 02-28-2010, 03:47 PM   #11
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
Mine does this too - exactly how u say. Stays at 600 and then drops to sub 500 rpms, except my car shutters slightly when it does this. Should I up my idle rpm to say, 700?
Nvm i guess you can't since its electronic - guess i just have to live with it :(
sk8manmike is offline   Reply With Quote
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 01:40 PM
No RPM signal? Any ideas? XYaris DIY / Maintenance / Service 5 06-28-2009 04:47 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 05:35 PM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 05:16 AM
