Old 11-14-2006, 09:13 PM   #73
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Originally Posted by regulus
And please dont act like you know it all, allow other people to have different opinions
Opinions are not facts you seem to have that confused....
tomjasz is offline   Reply With Quote
Old 11-15-2006, 02:44 AM   #74
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Well it could be you had higher oil pressure because some passages were partly blocked restricting the oil flow. Using an engine flush and using synthetics will remove the deposits and may be causing the low oil pressure
OR maybe he used a lighter oil.
OR there could have been a build up of crud in the sending unit.
Synthetic don't tend to thicken over time like mineral oils do either so you may see slightly less pressure on the guage
If it's a huge drop I would recommend testing the oil pressure.
If it's a higher mileage engine use a slightly heavier synthetic oil say a 10W-40
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 11-15-2006, 02:47 AM   #75
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Why would you change to synthetic when you need to bring in the car anyways for the other stuff they do during oil changes. Filters, break liquid, tire pressure...., whatever they do.
You don't need to bring the car to the dealer to have the tire pressure checked or to replace the cabin air filter, If you can change your own oil you can usually check the rest of the required stuff (except maybe the valve clearance) But hell even that can be checked by anyone but should be left to someone that knows what they are doing to adjust them.
Old 11-15-2006, 04:00 AM   #76
Black Yaris
der Zeck
Black Yaris's Avatar
what do ya'll think of 0w40 it is a very common weight oil for European cars
Old 11-15-2006, 12:09 PM   #77
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
That would be perfect for an engine with high mileage
I run 0W-40 in my motorcyles
Old 11-29-2006, 06:20 PM   #78
bigsky2
Cousin Vitz
bigsky2's Avatar
This thread has bee a very good read.
07WYarisRS
I am planning to change to synthetic in the spring.
My current mileage is 10,000 km.
From reading the previous posts, it seems like an oil flush is not necessary when changing from conventional to synthetic at lower mileages (ie. 8000 km a lower)
I'm planning on changing to synthetic perhaps around 14-15K km, depending on the weather.
Should I perform an oil flush at that estimated mileage, prior to using synthetic?
Old 11-30-2006, 10:48 AM   #79
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
07WYarisRS
Can't hurt. A flush will just make your oil stay (look) cleaner for longer by removing any contaminants in your crankcase.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 11-30-2006, 11:11 AM   #80
Couple of questions... I'm planning to take a road trip around christmas, and I think I should get an oil change as well as a "just-in-case" checkup before I go.
So I'll be going synthetic after reading the wealth of information in this thread.
Question #1: Redline, Amsoil or Royal Purple come is as highly recommended, but over here, as far as I know, are not available. Mobil 1 seems to be all right too, but what about Castrol? We can get GTX, Syntec, Magnatec, and so on, are they any good? Or else there's the usual Shell and other common brands.
Question #2: It's the tropics here, temperatures only vary between about 25 and 40 degrees Celsius, and I see that most oils sold here are 0W30-0W50, does the ambient temperature make a difference or should I stick with a lighter oil like 0W20 as recommended here?
Thanks!
Old 12-01-2006, 08:46 AM   #81
nsmitchell
nsmitchell's Avatar
Here is a comparison of oils. http://www.1st-in-synthetics.com/10W30API.htm
Get YarAss in gear!
RIP - Casey Tatum
Old 12-01-2006, 09:17 AM   #82
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Thanks!
You can order Amsoil online or I can put you in touch with my Amsoil guy and either he can ship it to you or know of someone or another place to order Amsoil from. Redline is also An excellent lubricant. Royal purple is decent but has had quality control issues in the past that I have seen first had with lab test results. Things like high copper levels, water and even grades being off. I would stick with Amsoil or Redline.
The rest like Mobil 1, Castrol Syntec, Motul, Qstate, pennzoil synthetics etc are all just highly refined crude/mineral based oil. IMO not worth the prices they charge
A 0w-30 wont hurt in any temp however if you live in a tropical climate a 5w-30 is all you really need. Stick with the 30W oils, 20W oils are super light. While they can help mileage ever so slightly too light of an engine oil on a car under heavy load orextremem temps or high rpm operation can shorten the life of the engine.
Old 12-01-2006, 01:38 PM   #83
JDMVitz
Obsessive Detailer
Drives: JDM
Originally Posted by FCP91
Motul 8100 0w30 all the way!!!!
I also use Motul 8100!!!
JDMVitz is offline   Reply With Quote
Old 12-24-2006, 05:48 PM   #84
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
im glad that i work at an autoparts store that sells amsoil . get it at cost :)
d2dailly is offline   Reply With Quote
Old 12-26-2006, 01:21 PM   #85
nsmitchell
nsmitchell's Avatar
You are one lucky dude! Do you use Amsoil PI? (Performance Improver)
Get YarAss in gear!
RIP - Casey Tatum
Old 12-26-2006, 10:53 PM   #86
d2dailly
Roar?
i will use amsoil 5w30 not sure what the preformance improver is but they carry a bunch of ish from amsoil and i get it for less than $5 a quart :)
Old 12-27-2006, 05:39 PM   #87
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
I think i already posted... but MOBILE 1!!!!!!!! My yaris only deserves the best and when i went to Mobile 1 for my first oil change i told them nothing but the best they have. no other oil can compete with synthetic mobile 1 oil
elsteverino889 is offline   Reply With Quote
Old 12-27-2006, 06:14 PM   #88
FCP91
NCP91
FCP91's Avatar
Drives: 06 Vitz RS
I used Mobil 1 before.... Can NEVER compare with the quality of MOTUL!!!
FCP91 is offline   Reply With Quote
Old 12-27-2006, 06:16 PM   #89
d2dailly
Roar?
sorry bud bet mobil 1 is only more refined than regualr oil its not truly man made if you want real synthetic go amsoil
Old 12-28-2006, 08:51 AM   #90
nsmitchell
nsmitchell's Avatar
That reminds me of a call I once got while working at Circuit City's Answer City. I was answering computer calls when this old man calls up and has a problem. Halfway through the call he said "I know quality and when I bought this computer I told the salesman, I want your best, so he sold me a Hewlett Packard Bell." The PC was a Packard-Bell Legend 2000. The biggest piece of crap ever to have a CPU. I pressed mute and started laughing until my sides hurt! I guess that makes me an old geek!
Here is the link to Amsoil PI. https://www.amsoil.com/storefront/api.aspx
Get YarAss in gear!
RIP - Casey Tatum
LB M/T options Howard2621 New YARIS Purchase Forum 1 09-22-2006 10:37 PM
