#19 | |
![]() Drives: Yaris 1,3 -01 Linea Luna Join Date: Feb 2010
Does that relay kit look right and working which I posted few messages before? |
#20 |
Yes, you definitely need a relay. I am not familiar enough with the wiring for that generation of Yaris to be able to tell if the relay kit in your picture will work.
#21 | |
![]() I was just confused because Bixenon kits come with relay which controls the bulb for low/high beam but the kit need the additional relay kit for fooling the Daytime running light.. The relay harness gets power directly from battery but normal bixenon system do the same. Basically there is no difference by using original h4-bixenon system or relay harness. Both get the switch from car's original h4 socket. So what is the difference? Maybe I am stupid but I don't get it... anybody help Last edited by Falconia; 02-17-2010 at 03:43 PM. |
#22 | ||
#23 | ||
This seems to be my monolog but, I get the fron dash off with CTScott instructions! That was easier than I expected and the DRL was right under the dash. Thanks! I found the DRL module with number: 82810-52020 whic differs from DIY instructions (http://www.yarisworld.com/forums/showthread.php?t=894). In this DIY number was 82810-52040. I think that module I found is DRL because google search: 82810 RELAY ASSY, RUNNING LIGHT 82810‑52020 NCP1*, NLP10, SCP10..JPP..LHD..(LUNA, SOL, TRSTD, TS) 1 http://www.toyodiy.com/parts/p_E_200...html?hl=85916D So, yei! Problem solved (hope so..) |
#24 |
That's correct. Your generation of Yaris had a different part number than the newer generation.
If simply disconnecting the module doesn't do the trick, then snap a picture of the connector. If the EWD that I have matches the wiring for your area, then I believe that you will need to disconnect the yellow wire (between the two greens) and leave the module in place. |
#25 | |
What EWD do you have? Last edited by Falconia; 02-19-2010 at 04:51 PM. |
#26 | |
#27 | ||
Does the EWD which you have "say" that I have to disconnect just a yellow wire. Or does it say that in US 2001 Yaris DRL have to be completely disconnect. Quote:
#28 | |
For the second question of Yellow or Blue, he is talking about a 2nd Gen Yaris DRL, which is wired completely different than the first gen DRL module. |
#29 | |
UPDATE! I finally got DRL removed and like CScott said any lights did no light up. Including headlights, taillights or panel lights. CTScott you said that I have to cut yellow wire from DRL socket. Could you explain what that wire is and what it does. If I cut that wire, tail lights, panel lights and so on working when turning lights on from circuit braker (don't know what the controller next to the stering wheel is in english)? Last edited by Falconia; 02-21-2010 at 08:46 AM. |
#30 | |
#31 | |
Yes, there is yellow between two greens. I was surprised because all lights stopped working when I unplugged the DRL. If I cut that wire tail lights as well as headlights still working when I manually turn on the lights? Right? |
#32 |
I believe so. To be safe, either pop the pin out of the connector, or cut the wire with enough left on the connector side to be able to reconnect if that doesn't work.
#33 | |
#34 |
![]() ![]() Drives: 2010 Yaris 3-door liftback Join Date: Mar 2010
I have a 2010 liftback and the manual mentioned DRL. But when I turn on the car the headlights do NOT go on. ??? Should I complain?
#35 |
#36 |
Hi again,
I have now the second Bi-xenon bulbs in my Yaris. These new bulbs has worse flickering problem compares to older ones. Passenger side bulb is flickering especially when starting engine, pretty bad I think. My hid is connected directly to the battery. I have heard about relay harness, but is that going to change anything because my hid is already connected directly to the battery. What about capacitor decoder which is used to flickering also, that stables the current, I think. How I resolve flickering problem in that situation? Relay, Capacitor?! ...and I have hi/lo kit where relay harness came with the kit |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 07:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 07:46 PM |
