![]() Drives: subaru impreza Join Date: Mar 2010
squeeking clutch on a d4d
as stated above we have a 2002 d4d yaris in the family which has developed a squeek when you depress the clutch!and the local toyoa dealer recommends a new clutch@£600
the clutch feels finecheers steve |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
You need to provide more information. If it is the throw out bearing, it could mean a new clutch is in order.
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Yeah, need a little more description.
Is the squeak while the pedal is being depressed (the motion of the pedal is causing the squeak), or is the squeak constant AFTER the clutch pedal is depressed. If it's clutch pedal motion, could be the pivot point at the end of the clutch slave cylinder needs some lube, or even just the pedal linkage needing lube. If the squeak it constant when you push in the clutch, it could be the throwout bearing. The work required to replace the throwout bearing is 95% of the work required to replace the clutch, so you might as well replace the clutch at that point. Definitely get a second or third opinion before you go replacing the clutch! |
it squeeks only when pressed and the noise is from under the bonnet!
What?
If it's a very light squeak, it could still be the slave cylinder rod. Pretty common issue.
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 08:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 06:20 PM |
| ACT clutch kit | Jason@SportsCar | Items for Sale by private party | 11 | 03-31-2010 04:05 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 02:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 12:34 PM |
