Old 03-20-2010, 09:17 PM   #1
wholenizz
wholenizz's Avatar
Drives: 07 yaris hatchy
Thumbs down I messed up big time... Lowering springs gone wrong.
I've done lowering springs before, no problems. Well today I lowered my car, finished it all up, and then got in the car and turned the key. Put it in drive and heard *SQRREEEECH* I was like oh no! So I immediatly turned car off. Jacked it up, and my axle was popped out of the transmission. I broke a bearing and it popped out. It was never in the all way. Do I have to buy a whole new axle? Or can I just get that bearing that was on one of the 3 tips of the drive shaft? I'm refering to the shaft that goes into the transmission... Whats that called anyway? Axle or driveshaft? or what? So yeh big mess. Could be extremely costly for me right now I am not happy with myself. Lowering springs gone wrong!
wholenizz is offline   Reply With Quote
Old 03-20-2010, 10:03 PM   #2
DARK AGE 53
Drives: 2009 Yaris Onyx
Bummer, the shaft is called many things....CV Half-Shaft is one of them. Good luck with the repair.
Later,
Al
DARK AGE 53 is offline   Reply With Quote
Old 03-20-2010, 10:18 PM   #3
wholenizz
wholenizz's Avatar
Am i gonna have to replace the whole shaft? Or can I get the bearing I need?
Old 03-20-2010, 10:26 PM   #4
DARK AGE 53
my guess is a dealer will only sell you a complete half-shaft, check the local yellow pages and see if there anyone who re-builds half-shafts in your area.
Old 03-20-2010, 11:15 PM   #5
wholenizz
wholenizz's Avatar
cool I am hoping its just a standard size bearing or whatever thats really my only hope. Otherwise I just made a $300 mistake or more :[ I shud have just taken it to the tire place down the street for them to do the springs... I am so pissed at myself.
Old 03-20-2010, 11:37 PM   #6
Vb2ner
Team VAJJ
Vb2ner's Avatar
Drives: 2007 Yaris sedan Flint Mica
I don't understand why that happened? It's not like those springs would drop the car low enough to put your axle at such an angle that it would snap! I am tucking 14"s on my jetta, and my axles hit the body on occasion due to the car being so low, and I have never trashed an axle like that and you have to consider the angle that my axles are at as well.
I just don't see how a simple spring install could have broke your axle by the hub, which is what it seems like you are saying. It must have been on it's way out already or something. Post pics though, I am interested..
Ps: don't pay for a spring install, save your money, it is so easy and I doubt it was something you did
2007 Yaris Sedan DD, 95 VW Jetta boosted and laid out...stretch and poke FTW
Vb2ner is offline   Reply With Quote
Old 03-21-2010, 12:01 AM   #7
Kimmy
Loves to travel
Kimmy's Avatar
Drives: 2008 toyota yaris
Send a message via Yahoo to Kimmy
yikes im sorry that happened to you! Hope you can get everything situated and fixed
<img src=http://i64.photobucket.com/albums/h176/xxretard_monkeyxx/30u95p3-1-1.jpg border=0 alt= />
Kimmy is offline   Reply With Quote
Old 03-21-2010, 12:01 AM   #8
silver_vios
Drives: yaris sedan
+1 did you drive off without reattaching the strut??
silver_vios is offline   Reply With Quote
Old 03-21-2010, 12:03 AM   #9
wholenizz
wholenizz's Avatar
k ill get pics tommorow. I mean I guess it wasnt in there right. It pulled out when the knucle was loose free to move around detached from the strut. And it must have pulled out and got placed in there all funky.
Old 03-21-2010, 12:03 AM   #10
wholenizz
wholenizz's Avatar
no haha... I mean I had done this lowering spring job plenty of times before...
Old 03-22-2010, 02:59 PM   #11
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
When I put my springs/struts on, the axle got pulled out a bit. I just fussed with it and got it back in.
How do you know you messed up the bearing?
(Where in Oregon are you, by the way?)
Old 03-22-2010, 04:27 PM   #12
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
I have seen a axle pop out before but we managed to get it back in. PITA. I would call your dealership and see what they say first than call around to a few shops to see what they say. Calling doesn't mean you have to pay for it.
Always a recommendation that you could have used before this all went down. Keep your axle straight when removing the suspension. Place something/anything under the arm to keep it straight while toying around with the coil overs.
Edit: I don't think you will have to replace the whole shaft. Hell unless you are absolutely certain this cause a bunch of damage, I would probably see if I could get the shaft back in and see if it would drive, so that you can take it to a shop at least to have a professional look at it. That is unless your nearest shop is more than 50 miles away. Otherwise you may want to have it towed.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 03-22-2010, 04:30 PM   #13
wholenizz
wholenizz's Avatar
corvallis, OSU.
So uh turns out I can't just get the bearing im going to have to find a whole axle...
Old 03-22-2010, 05:39 PM   #14
I have a spare stock axle -- left or right side?
Old 03-22-2010, 08:50 PM   #15
Vb2ner
Team VAJJ
Vb2ner's Avatar
You should take pics, We could help you alot more! Regardless, if it's just an axle, that is easy and relatively cheap:)
Old 03-22-2010, 08:56 PM   #16
wholenizz
wholenizz's Avatar
ok i took pictures!
Old 03-22-2010, 09:04 PM   #17
wholenizz
wholenizz's Avatar
I just need the needle bearing off of it :[ check the picture I guess it's the half shaft? not the actual axle? :wu
Old 03-22-2010, 09:13 PM   #18
H3LlIoN
Drives: '09 Yarrrr hatch
If it's any consolation, it looks sweet slammed.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 10:03 AM
Progress Lowering Springs vs Tanabe DF210 lowering springs jyfro_13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-24-2010 03:38 AM
FS: Progress lowering springs Cvc9216 Items for Sale by private party 0 10-23-2009 08:41 PM
2006 Toyota Yaris 5dr. LiftBack Lowering Springs yaya Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-14-2009 02:38 AM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 01:23 AM
