So, I'm thinking about going Turbo... Questions
First off I'd like to say that I'm pretty new to car modifications so feel free to call me crazy for even thinking about doing this.
I love my Yaris, but I'm looking for more power... without drastically decreasing engine longevity and fuel economy. Bolt-on mods aren't going to cut it, and superchargers are out of my price range. Plus, I'd like the satisfaction of putting together a custom kit ![]() After my initial research, I've decided I would like to aim for approximately 140 hp and no more than a 6psi boost (if this is even possible.. seems like it is). I would really like to keep as much stock as possible. So here are my first set of questions: 1). So far, the Garrett GT25r and Turbonetics T3 seems to be the most approriate choices. The GT25 spools up at about 2000 rpm apparently, which would be great for a daily driver such as myself. Both of these are a bit steep though, and I can't find a used one on ebay. Are there any cheaper alternatives that spool up somewhat quickly? Would the Garrett GT22 work? Also - pros + cons of internal v. external wastegate? 2). A log manifold is definitely my first choice for manifold. It should be approriate for the set up I'm aiming for, correct? It would be great if someone could supply me with some specs for the manifold as well. 3). Found the answer. 4). What other parts of a turbo kit can I do without (at low boost)? I was reading somewhere that a BOV isn't really necessary, among others. 5). Fuel Management - will stock injectors and a stock pump work at low boost? Do I need a piggyback system such as the GReddy E-manage? 6). Will I need a sump for feeding the oil? 7). How important is tuning going to be if I'm able to keep almost everything stock, and simply add a piggyback system if necessary? Last edited by Focus_Sh1ft; 03-31-2010 at 02:34 PM. |
Drives: 07 sedan Join Date: Mar 2010
You're crazy :D
I believe you are running into the "cheap, fast, reliable - pick two" rule. Find a nice used blitz unit and call it a day. |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
based on what you posted, please step away from the toolbox
yarr sez it best. get a blitz unit, follow the instructions, have a nice day. |
Learn to Relax
Blitz.
#6 | |
might have a deal coming up soon on a Blitz
![]() and yeah, anything more than that is a serious project. Even getting the Blitz installed right is tedious and of at least medium difficulty. Quote:
#7 | ||
I'm also beginning to realize this may not be worth it, as the cost of a low boost through Turbo may just as well run as much as a used Blitz. Nonetheless, this is something I'd like to try ![]() EDIT: http://www.yarisworld.com/forums/showthread.php?t=20426 Quote:
Found another mention here: http://www.yarisworld.com/forums/showthread.php?t=17681 Garm, I'm not trying to call you out, but at the same time I kind of am lol. You clearly know the most about FI in a Yaris, so your feedback is most valuable
Last edited by Focus_Sh1ft; 03-31-2010 at 02:48 PM. Reason: trying to avoid looking like an idiot lol |
Riceman43
And has this happened yet???? |
#9 | |
It's not going to be cheap, a lot of research and testing goes into developing a turbo kit and an ECU Map that works right without screwing up your engine. Get a kit that's made for the application and has some sort of support for the times when you have a question or a problem. |
** It's not a ball bearing turbo. You can also get a super cheap Chinese no-brand turbo, but god help you when it fails. The turbo is the most important part of the set up - don't cheap out on that one part. Also - pros + cons of internal v. external wastegate? *** Cost. Flexibility and tuning. Not easy to change an internal gate (different spring, etc.) 2). A log manifold is definitely my first choice for manifold. It should be approriate for the set up I'm aiming for, correct? It would be great if someone could supply me with some specs for the manifold as well. ** What do you mean by "specs"? 3). Found the answer. ** Huh? 4). What other parts of a turbo kit can I do without (at low boost)? I was reading somewhere that a BOV isn't really necessary, among others. *** I think it is. Overboosting/retaining boost off throttle are both dangerous. 5). Fuel Management - will stock injectors and a stock pump work at low boost? Do I need a piggyback system such as the GReddy E-manage? *** Yes they will at the 6psi target. 6). Will I need a sump for feeding the oil? *** No. Just install your return line as high as possible. I tapped mine into the block, because we don't really have much of a "pan". 7). How important is tuning going to be if I'm able to keep almost everything stock, and simply add a piggyback system if necessary? *** This is two questions, not one. 1. Tuning is critical, period. BUT you may not need it if you set up a low-boost system correctly. 2. Find successful piggyback installs on here or anywhere on a Toyota Yaris. It's a challenge!
| Thinking about buying 5dr Yaris, just have some questions. | Justnobody | New YARIS Purchase Forum | 4 | 10-04-2009 03:40 AM |
| Thinking about a turbo, not enough knowledge to do myself... | goku87 | Forced Induction Forum | 3 | 09-04-2009 09:36 PM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Turbo Questions | regal | Forced Induction Forum | 54 | 04-06-2009 07:38 PM |
| Turbo Questions | regal | Performance Modifications | 0 | 03-27-2009 02:07 PM |
