![]() ![]() Drives: 2010 Black 3dr Lift Back Join Date: Nov 2008
Anybody have a front sway bar on the hatchback? I've been autocrossing a lot lately and want to get rid of some understeer.
My current set up is DF210s, Tokico HP's, 23mm Ultra racing rear bar |
Try disconnecting the front bar from the control arms first and see how that goes.
Edit: sorry, disconnect from the struts on the Yaris I believe. You want less front sway bar if you have understeer. |
what are your alignment specs? a larger front swaybar is going to INCREASE understeer.
![]() Drives: 2007 Yaris HB Join Date: Apr 2010
Um, I'm pretty sure that a larger front sway bar increases oversteer and a larger rear sway bar increases understeer.
*edit* Ah, you're right: "Understeer or oversteer behavior can be tuned out by changing the proportion of the total roll stiffness that comes from the front and rear axles. Increasing the proportion of roll stiffness at the front will increase the proportion of the total load transfer that the front axle reacts and decrease the proportion that the rear axle reacts. This will cause the outer front wheel to run at a comparatively higher slip angle, and the outer rear wheel to run at a comparatively lower slip angle, which is an understeer effect. Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer." |
The Yaris likes a bigger front sway bar a lot. I know on paper it makes a car understeer more, but the reduction of excessive rolling helps the front end stick better in this case.
#6 | |
1st mod project at 35
Drives: 2008 Yaris Join Date: Apr 2010
#7 | |
totally different
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 11:52 AM |
| front sway bar question | thom25 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-25-2009 07:54 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
| Yaris 24mm Front Sway Bar | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-09-2009 02:33 PM |
| FS: NEW C-One Front Sway Bar & 4-Point Brace NEW LOWER PRICES! | 03Z33 | Items for Sale by private party | 1 | 06-06-2009 01:29 AM |
