Old 04-27-2010, 02:30 AM   #1
cutter
Cutter
Drives: 2007 yaris hatchback 5-speed
Steep start
Hi ... just found this site. I drive a 2007 yaris 5-speed hatchback. Most driving is in & around Seattle, with its many hills
& frequently slick streets. Several times starting from stop on a steep hill -- especially, but not always, if pavement's a
little wet -- it won't get traction. Front wheels spin, tires get hot, back end is a bit squirrelly. has anyone had similar problems?
cutter is offline   Reply With Quote
Old 04-27-2010, 12:19 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You've got to let the clutch out very smoothly and not let the car start rolling back. It's good practice to start with your parking brake on, and let it off just as the clutch begins to engage.
Old 04-27-2010, 12:53 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Smoother throttle input. Better tires.
Old 04-27-2010, 04:31 PM   #4
Zaphod
Drives: Big Yellow
I have noticed that happen when I accidentally dumped the clutch.
Did you just get the car? The clutch and throttle takes a little getting used to. Heck, my girlfriend starts in 1st better than I do.
It's all what you're used to, and I'm still spoiled by higher torque and smoother clutches.
But fear not, you'll be a master of the car soon enough. I would also suggest using the cable brake for smoother starts on hills.
Zaphod is offline   Reply With Quote
Old 04-27-2010, 04:44 PM   #5
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
if all else fails and you just want to get going, try the ebrake method..I usually do this when I am starting on a steep hill AND the car behind me is too close up.
this way you can minimize the rollback. But...can't be good for both brake and clutch so i dont recommend doing this all the time. Only when you are in a tricky situation
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 04-27-2010, 05:32 PM   #6
Loren
What?
Loren's Avatar
Not going to hurt anything by using the handbrake to keep from rolling back when starting on a hill. It's just seen as "bad form" by us stick-shift snobs. :)
Old 04-27-2010, 10:08 PM   #7
Shijima
Drives: 07 HB
If it feels good, do it.
Shijima is offline   Reply With Quote
Old 04-27-2010, 10:19 PM   #8
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
It's the toughest clutch I've ever had to learn.
bkrownd is offline   Reply With Quote
Old 04-27-2010, 10:21 PM   #9
bkrownd
bkrownd's Avatar
OTOH, not using the handbrake is considered bad form in many countries. They think we don't know how to drive in the US.
Old 04-27-2010, 11:16 PM   #10
Loren
What?
Loren's Avatar
Yeah, egos aside, if you're trying to get a launch up an actual hill (not much in the way of hills here in FL), using the handbrake really is the way to go.
Old 04-28-2010, 10:52 AM   #11
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
What tires are you using and how many miles on them.
Old 04-28-2010, 12:56 PM   #12
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Well.... I would bet there are no stick shift snobs that live in Seattle then, cause there are some mean hills with plenty of stops on them.
Old 04-28-2010, 01:31 PM   #13
Loren
What?
Loren's Avatar
I'll put it this way: An experienced stickshift driver should be able to hold a car in place +/- a couple inches on most hills. DOING that is bad for your clutch, so you shouldn't. But, you should have the skills to do so. Having those skills in combination with using the handbrake (I'm a fan of having tools in the driving arsenal!) will get you smoothly up any given hill.
Old 04-28-2010, 02:29 PM   #14
Zaphod
Drives: Big Yellow
This is true, I've always felt like people should practice using the hand brake anyway.
But I've actually had a master cylinder fail, so I do know the value of being proficient with the cable brake should the hydraulic system go out
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 12:39 PM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 03:20 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 11:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 09:53 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
