Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i Join Date: Nov 2009
Oil light coming on and off
Any1 else have this problem at roundabouts or sharp turns?? and should i get it checked?
Drives: 07 sedan Join Date: Mar 2010
get it checked. In the US anyways, by the time an oil light comes on your engine is a goner.
If your oil light is coming on on corners it means you only have about quart or less of oil left in the engine. As you turn the little bit of oil swishes around in the pan and the sensor is uncovered with oil for a bit and light comes on. As car levels out oil does and sensor turns light off again.
Id check your oil level first. More than likely your oil change is past due. Or your leaking oil. |
AKA Samurai Racer
thats oil surge , make sure it filled up :-)
![]() ![]() Drives: CHR 1.8 Hybrid + Yaris gen3 Join Date: Jul 2009
fill it up to max inmeditly
Colin Richardson
its filled... 2ltr of mobil super fe 5w-30 semi.. scared ive fucked my engine now lol im a para case :(
#7 | |
