Old 05-08-2010, 03:49 PM   #37
ddongbap
I don't think theres a "better". They both respond differently to different types of alignment and tire setup.
I just want balls out, so I went 23mm.
But the difference is like getting Super Size with your Double Quarter Pounder with cheese meal.
Old 05-08-2010, 05:08 PM   #38
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
Originally Posted by Mister Z View Post
I believe the TRD is 19 mm
i thought the trd was closer to 24mm
SLIK4 is offline   Reply With Quote
Old 05-08-2010, 08:16 PM   #39
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Talking
Originally Posted by Falconeer View Post
so who has 19 and who's got 23? Which one is better?
I have 19mm and it has been awesome! and YES ...........TRD is 19mm
NOTE:
I've been adding weight (deadening my car and subwoofer box) and my new wheels stick out a little bit more so I think I'm
going to upgrade to 23mm.
http://www.yarisworld.com/forums/showthread.php?t=26150
CLA 250, 4MATIC
Old 05-08-2010, 10:10 PM   #40
MadMax
MadMax's Avatar
I believe the 19mm is good for street use, and if you want to autocross then you should get the 23mm. However, the bigger the bar, the stiff your suspension would be, so the decision should be based on your driving skills and habits...
Old 05-08-2010, 11:04 PM   #41
RedRide
RedRide's Avatar
Yes,the bar does stiffen the rear suspension and I assume the 23mm will stiffen it a bit more then the 19mm.
However I feel the ther rear is too soft as compared to the front in the stock configuration.
After adding the 23mm bar, to me, it now seems just about equal front to rear.
Personally, I have no problems using the 23mm for street/dd use.
Old 05-09-2010, 01:23 AM   #42
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
The rear swaybar only "stiffens" the rear suspension when the car is cornering or when one rear wheel encounters a bump or hole that the other one doesn't. Typical straight line ride quality is unchanged. That kind of change in stiffness can only come from stiffer springs or shocks.
Old 05-09-2010, 02:48 PM   #43
Vang
Drives: 2008 Yaris Sedan
so it wont really help in preventing highway wander during crosswinds?
Vang is offline   Reply With Quote
Old 05-09-2010, 03:05 PM   #44
Everyone I've talked to who installs a sway bar in the Yaris reports more stability in crosswinds. You'll find lots of posts to that effect all over the forums here.
Old 05-09-2010, 03:12 PM   #45
RedRide
RedRide's Avatar
Actually it does to one degree or another.
It should be understood that even on the highway, traveling in staight line, the suspension is constantly flexing and the end result is one side will hinder the flexing other with the sway bay installed and therefore, stiffen the suspension feel. Rarely does the road want to compress both sides of suspension equally.
Of course, one can argue just how much stiffer it will feel and also the 19mm vs the 23mm.
Old 05-09-2010, 03:47 PM   #46
Loren
What?
Loren's Avatar
The suspension "sees" a crosswind the same as it does a turn. The body rolls, once side compresses, the other side extends. A swaybar will limit that movement.
The calculation of bar "stiffness" (resistance to twisting force) is a function of its diameter to the 4th power. A 23mm bar is a lot stiffer relative to a 19mm bar than it might seem at first glance. While the 23mm bar is only about 21% larger diameter, it is MUCH more than 21% stiffer. Roughly: 23^4/19^4 = 280000/130000 = 2.15. The 23mm bar is over twice as stiff as the 19mm bar.
Old 05-09-2010, 03:49 PM   #47
SamH
Drives: Bayou Blue Yaris Hatchback
Simply: Feels like u are driving on rails... its awesome I got the 23mm and it rocks.
SamH is offline   Reply With Quote
Old 05-12-2010, 12:27 AM   #48
sickpuppy1
Drives: 2010 Yaris Sedan
And that's where I'm at, I know I'm going to get one soon, but debating between the 19 and 23. I just a daily commuter, 55 year old fart with a young heart (except the cholesterol) and I want better handling, not sure if the 23 would make it too stiff. Probably should go with a 19 since it still is gonna be a vast improvement over stock. But don't wanna end thinking , dang,I shoulda got the 23 after all,.......It's not like I'm gonna go gymkhana racing or anything.
Old 05-12-2010, 12:34 AM   #49
sickpuppy1
I'm still cruzin on stock tires and rims. Saving money for when I need new tires I'll be sporting new wheels too, cant wait!
Old 05-13-2010, 03:35 PM   #50
trebparadise
Drives: sedan yaris y
Hi there,
which sway bar size is better for 205/60/r14 wheels/tire?
trebparadise is offline   Reply With Quote
Old 05-13-2010, 03:36 PM   #51
^ first, read the posts before this one. Then, buy the 23mm sway bar, or the 19mm for $30 less.
Old 05-13-2010, 04:19 PM   #52
127.0.0.1
questions on the Ultra racing 23mm
1) what kind of paint ? is it powercoated, or fairly resistant to
corrosion ?
2) the welds, any warranty on the welds ?
are they in stock ?
anyway, i am gonna get one of these 23mm jibbajobbahs and slap it on and post my results
right now, in crosswinds, my Yaris is like an itchy bear cub
I can get a TRD for 180 bucks from dealer. for less $$ I can go stiffer, so microimage will see some funds
from me soon.
EDIT: UltraRacing is ISO 9001
I am no longer concerned
Old 05-13-2010, 08:47 PM   #53
minnyar
Drives: 2007 Yaris Sedan (5pd)
Mine was powder coated, before my dumb ass scraped it to hell installing it. Make sure you put a blanket/towel under your car when installing!
Just buy it, not to expensive, and it makes the car feel so much more solid. Why bother with the 19mm other than you saves you $30.
minnyar is offline   Reply With Quote
Old 05-14-2010, 10:28 AM   #54
deadcrow
Drives: yaris ts 1,8L 133hp
sway link
hey :) i search shorter or adjustable sway links but i don t know where i can get this....
greetings
deadcrow is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
